Question about HP Photosmart 325 InkJet Printer
I recently bought an HP Photosmart 325 on eBay and my prints are very green"ish". The ink level is 66% and the print setting is on "Best". I am using the HP photo paper and have done the clean and align cartridge procedures. Anything else I can try?
  • 1,557 Answers
The reason for the green is that your red cartrige is not working to its full extent this could be one of two things. 1 your red is empty 2 the filter on the red is jammed. your best solution is to buy another set of inks and youl find it works fine.
Posted on Aug 02, 2010
Hp 7960 prints in all green
it sounds like another color could be low or empty
Nov 20, 2012 | HP PhotoSmart 7960 InkJet Printer
Where do I go to find how much ink has been used
To check the ink levels from the printer control panel
1. Press Setup.
2. Press the down arrow button to highlight Tools, and then press OK.
3. Press the down arrow button to highlight Display Ink Gauge, and then press OK.
The product displays a gauge that shows the estimated ink levels of all cartridges
installed.
4. Press any button to return to the Tools menu.
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the ink cartridges appear.
Replace the ink cartridges
Apr 14, 2012 | HP Photosmart C6380 All-In-One InkJet...
I just bought a hp photosmart c3140 tri-color cartridge. after 8 small prints the ink low level lights flash-rendering my printer unusuable. i re-fill the tri-color, and reset the printer. still the...
I would be taking it back to the place of purchase and asking them to replace it. Or contacting HP directly with the problem.
You can contact HP via their home page of their website, or use the link below for troubleshooting and support:
http://welcome.hp.com/country/au/en/support.html
NOTEs:
1. Unless you are printing a final copy of an item it is a good idea to always print in Draft Quality (to save your ink). HP Printers allow you to do this. This setting is generally within the Print window, when you select Print.
2. When you are printing a final copy then switch from DRAFT to BEST quality.
Feb 10, 2010 | HP PhotoSmart C3140 All-In-One InkJet...
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
Installed new yellow print cartridge for HP printer, prompts to install new cartridge but my ink level says full
I have this same problem and some sites said to uninstall the software then download the software from the HP site and reinstall it. So I am giving that a try tonight
I’m happy to assist further over the phone at https://www.6ya.com/expert/barbara_87cfe34e34050f26
May 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
Won't print black ink
I am on my second Photosmart C6180, the first one I had quit printing black ink after 6 months, after hours with the HP help desk, the finally decided to replace the printer. I have now been using the replacement for several months and just this weekend it too quit printing black ink...no copying, no printing and no faxing.  I am now shopping for another, not a HP.
Sep 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One Is printing All Documnets Faded Colors
Try to clean your printheads or check the level of your inks, maybe you are low on inks. Operating system does not affect any printing outputs as I know. Check your inks also coz HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.
If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
Replace any empty print cartridges. To check ink levels, follow the steps below.
  1. Press the Setup button.
  2. Press the down arrow button until Tools is highlighted.
  3. Press OK .
  4. The Display Ink Gauge selection should be highlighted. Press OK and the ink gauge will display.
OR try calibrate the color:
  1. Open the printer Toolbox :
  • Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
  • If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
  • Click Settings .
  • Click Print Settings .
  • Click Printer Toolbox .
2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
If the steps above did not help, clean the print head.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Please let me know if these steps helped you or not. Thanks
Jan 02, 2008 | HP Photosmart C6180 All-In-One InkJet...
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart 325 InkJet Printer Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
