Question about Gateway Essential 400 PC Desktop
My husband changed the size of the print on my computer,and now I can only get 4-5 words per page.What do I do?
    Scholar:
  • 72 Answers
If you are referring to Internet Explorer, you can click Page, Zoom, and change the zoom back to 100%. Firefox is similar, click on the View menu, followed by Zoom, and Reset. There should be similar options on different applications. Please let me know if this doesn't work, and if not, which application does this occur with?
Posted on Aug 02, 2010
Image Class 4150 - Getting error message telling me the correct paper size has not been selected but it has. Will only print or copy the first page because of this issue. Only solution is to reboot machine...
Hello Dear,
The problem you are facing is because the actual paper size you are using is different from the paper size you have registered in the software from you are giving print command. i.e., supouse you are using ms word you need to change paper size as per the actual under Page Setup tab of File Menu, this will surely solve your problem, or please revert for more clarification.
Regards,
Manoj Joseph
May 25, 2010 | Canon Office Equipment & Supplies
Prints PDF documents VERY slowly (4-5) per page
The actual issue you will find that its not so much the actual printing part of the process that is slow, its actually the spooling to the printer that takes the time.
Does your printer support PostScript printing ? (PostScript is a printing & imaging standard used by many printers) To find out if your printer does indeed support this either refer to your manufacturers documentation or perform a test page and look to see if you have a PostScript enabled option.
If your printer does support PostScript, make sure you are using its PostScript printer driver, most of the time we generally use PCL drivers, so simply change this.
Regards....
If you find your printer does not support PostScript there are a few other tweaks we can implement to increase printing speed.
Firstly we can force PDF files to be printed as graphics as opposed to text, to do this launch your chosen PDF viewer, select Print > Advanced > Print as image
Lower the print resolution, if we lower the print resolution most of the time the difference is very small, but it can reduce the actual print size of the document by up to 300%, which can greatly decrease printing times.
Make sure you are using the latest version of any print drivers or your chosen PDF printing program, normally Adobe Acrobat.
If the printer only has a small amount of memory if possible add more, if possible install a PostScript SIMM.
Check the amount of ram your computer currently has, check memory usage from task manager when printing to ascertain usage
May 19, 2010 | HP Color LaserJet 2600n Printer
Hi we use hp 1280 deskjet printer now facing problem that a4 size printing is good but a3 size is not printing .its giving blank page
sir it is because when you change the paper for printer you also have to change the size of the page in the computer if you are like using MS word you change its Page size too. that is why it is giving blank page. changing it size in computer would work.
Nov 11, 2009 | HP DeskJet 1280 InkJet Printer
How do I change the print size on my D4160 hp printer
There basically two approaches to changing the print size of your printer whether D4160 printer or any modern other particularly hp printer.
1. Go to file/print or simply do ctrl P on your keyboard. The print menu pops up. Go to properties/features. When the features tab opens look for resizing options. Under resizing options you will see print at actual size and scale to paper size. Select scale to paper size and list box will activated. Select the paper size to scale to from the list. If you are not familiar with paper sizes then this list introduction should do. The conventional official paper size is A4, half of that is A5, and half of that is A6.
2. The other procedure is to simply right click on the image and select print. A print wizard pops up. It enables you to chose size of images and automatically fits them into 1 per page, 2 per page or 4 per page depending on how many images you selected in the first place. However this is meant specifically for images/photos.
3. Again you may decide to physically resize them in the application (Word, CorelDraw etc) you are working with before sending print.
Sep 03, 2009 | HP Deskjet D4160 InkJet Photo Printer
Trouble printing book made in Word 2007 using a HP psc 1315 print
Select the Page Layout tab, in the page setup group, select margins, The at the bottom, select custom margins. on the margins tab about 1/2 way down, select the down arrow next to Multipl epages and select 2 pages per sheet. Print a couple test pages and see if that is the setup you need.
Apr 06, 2009 | Microsoft Word 2007 for PC
Trying to print multiple images on one page
Unless you have Adoby writter or another software that writes in Adoby PDF format all you can do isto  copy and shrink the four at a copy place.Phisically  fit the four onto one sheet and make copies. Sorry  Adoby is propriatory format and windows word nor most others word processors will not reformat nor change it.
Mar 15, 2009 | Office Equipment & Supplies
Number of pages
If you use ALL small type, it will be 20 pages. Seems like the thing to do, but if you must use 21 pages, you can use 17 pages of small print (40,800), and 4 pages of large print (7,200) for a total of 48,000.
Oct 17, 2008 | The Learning Company Achieve! Math &...
Print size
Hi carole. Looks like the the page setup has been changed. Click on File->Page Setup and adjust the values as per requirement. Let me know if you need more help regarding this.
Jul 20, 2008 | HP Photosmart C4180 All-In-One InkJet...
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
Computers & Internet Logo
29 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
