Question about Refrigerators
Replaced thermostat on Elkay water cooler. Compressor still doesn't turn on.
  • 1,557 Answers
I would replace the relay on the compressor (the little black box that the power runs to) as there can be very little else wrong. unless the compressor has jammed then it will have to be replaced but its such a rear thing. id look at the relay.
best of luck
Posted on Aug 02, 2010
My Elkay water fountain is clogged up, water does not drain properly, how do I unclog
To unclog the elkay water fountain just look out for push button catridge and and turning it to adjust how far it is pushed or you can even try with chemical drain cleaners like draino or liquid plumber or CLR(Calcium,Lime and Rust Remover) & if still the problem hire plumbing repair services.
All Plumbing Repairs
Apr 29, 2015 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Water cooler problem
HAVE YOU CHECKED THE THERMOSTATS THEN RESET THE UNIT
May 10, 2012 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Compressor stays running always but water warm
The refrigerant system has a leak and all of the freon has leaked out...
You will need to have a pro find the leak, fix it, vacuum and recharge the system again..
heatman101
Aug 10, 2011 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
This fountain is located at my church, the problem: The water dispenses, then it doesn't. Wait a while and it dispences again, then it doesn't. It did not do this before now it does...
sounds like there is a build up of minerals in the water line that is coiled around the cooler unplug from wall take off cover and run fine wire through copper tubing
Aug 02, 2011 | Elkay EZS8-L Single-Level Wall Mount Water...
HOW DO YOU GET THE EKLAY WATER FOUNTAIN APART TO REPLACE SOLENOID SWITCH
I have written up the entire process with all the steps and lots of pictures on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html
Sep 16, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
How can adjust the volume of water coming from the drinking spout on my Elkay water fountain?
On our Elkay drinking fountain there is a set screw underneath that you can turn to adjust the flow rate. I have detailed how to adjust the flow along with how to replace the solenoid on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Mar 19, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
Elkay water cooler does not turn on
You need to first check the circuit breaker for that wall outlet, and see if you short circuited it from water going behind the wall. if that is the case you need to reset it at the circuit box and then run a bead of clear silicone on the back of the water cooler to prevent water from dripping down the back .
May 30, 2009 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Need temp control for water cooler has BOTH HOT/COLD
Company called Ranco makes replacement contols. Contact your local Appliance Parts Dealer.
Apr 22, 2009 | Refrigerators
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
