Question about ViewSonic PJ500 Multimedia Projector
My Viewsonic PJ500 , The white bottom meets yellowish, and the edges that are black, they meet blue. Thanks!
  • jabo_barrera Aug 02, 2010
    I entered to the secret menu and was doing adjustments in the ghosting, but do not come to any solution. Also I disarmed the projector, and checked the filters, but they do not meet burnt, the strange thing is that the blue color in blacks and the yellow one in whites, they came from one day to the next, it was not gradual.
    Thank you!
    Thank you!
    President:
  • 1,099 Answers
if this is a DLP projector then the light tunnel needs to be adjusted or replaced or the colorwheel index needs to be adjusted if what you are describing is ghosting of sorts.
If this is an LCD projector your green lcd panel could be burnt, or you could have true ghosting that needs to be adjusted with the options in the hidden menu and should only be done by someone who knows what they are doing.
Good luck
Posted on Aug 02, 2010
What is the tension settings for normal over locking with the Elna 4de
First of all ensure that the serger is threaded correctly.
The two setting which you mention are really a 'range' for an 'average' setting.
Using 'average' fabric such as a medium weight cotton, flannel, etc.; set each of the tensions in the middle of the range and test the stitch. There may be minor adjustment required to get a perfect stitch.
Once you have stitched that first sample, here are some possible minor adjustments required:
1. Tear-drop shaped loops on the underside: Check that the thread is firmly set in the tension dial by giving the needle threads a good snug pull above the tension dials while the presser foot is down.
2. The zig-zag like thread on top should meet the ziz-zag like thread on the underside right on the fabric cut edge. If the meeting happens on top: reduce the upper looper tension slightly and increase the lower looper tension slightly ... test sew and recheck. If the meeting is on the underside: increase the upper looper tension slightly and decrease the lower looper tension slightly ... test sew and recheck.
3. If the meeting does happen along the fabric cut edge but the meeting is hanging beyond the fabric cut edge: increase the blade position (that is, move the blade to the right). If the fabric is creating a ridge or tunnel; move the blade to the left slightly.
Please let me know if this has solved your problem. Otherwise let me know what is happening with the stitch quality.
Sep 16, 2014 | Sewing Machines
Samsung hcn5529W hmdi input dispaly issue
then try using RY able instead of HDMI input to test if its a cable problem
Mar 29, 2008 | Samsung HCN5529W 55" Rear Projection...
How to check and replace window switch
Look at where the blue part meets the black and white. If there a clips press on both side to release it from the black part. If there are not any clips pull gently to see where the clips can possibly be detached
Jun 07, 2013 | Clothing
Viewsonic PJ500 bulb does not come on
Hi.
Look at the base of the bulb at the filament in the center of the bulb, if buldging change he bulb first. If the porblem continues then have the units Ballast or Sometimes called the lamp driver check and replace if defective. The cheapest way is the check the voltage at the lamp connections in the housing for At least 280 volts, while turning on the unit you will need a voltage meter to do this.
Mar 03, 2010 | ViewSonic PJ500 Multimedia Projector
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
Pj500 veiwsonic
1. Switch the power on.
2. Hold the Reset Button down for three seconds until the lamp timer is displayed at the bottom of the viewing area.
3. Press the left arrow to select 0. Then wait for the lamp timer display to disappear.
Lamp Timer is now reset.
Feb 25, 2009 | ViewSonic PJ500 Multimedia Projector
Mitsubishi CS-40707 Greenish/Yellowish Display
Yeah, I had mine checked for the same thing. The "blue" - There's only three - red yellow blue- portion of your tube died. Not repairable. Last I checked it costs at least $1,000 for a new 40 inch tube. Good luck. Mine went to the garbage dump!
Feb 25, 2008 | Mitsubishi CS-40707 40" TV
Convergence error on viewsonic projector PJ820
your gonna need to get a service manual from the manufacturer and do a convergence alighnment with the on board generator. Unless some unknowing hands have been inside the unit.?? Contact them here at this link Good Luck service.us@viewsonic.com
May 07, 2006 | ViewSonic Projector PJ802 Pro Multimedia...
ViewSonic PJ500 Multimedia Projector Logo
218 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
