Question about Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft. Conquest Side-By-Side Refrigerator w/ In-Door-Ice Ice Dispensi...
Whirlpool icemaker/water stuck on.
I have a 2005 Whirlpool Gold model #GC5SHE. The water for the ice maker stuck on and flooded the kitchen. Am I correct in assuming this is the water valve stuck on? If so, how do you change the water valve and is there a diagram availble for the parts involved?
3 Suggested Answers
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
  • 1891 Answers
SOURCE: the icemaker whirlpool gold model GRZSHWPBOZ
either the water valve is bad if so replace it or the tube that delivers the water to the tray is frozen . ck both and replace the one that is bad . hopt this helps mm ..
Posted on Apr 06, 2010
Whirlpool Gold icemaker won't make ice
Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
If the ice maker does nothing then replace the=>
2198597 Ice Maker Assembly
Thanks John Tripp Appliance 911
Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
I have a Whirlpool gold french door model # GI5FSAXBY02. The icemaker stopped making ice -please advise. Thanks. Charles Mara chrlsmara@yahoo.com or cjmara@cox.net
Could you double check your model number. I am unableto pull that model number up. You mentioned that your ice makehas stoppedworking. This could be several things, like water control valve,defective ice maker, defective ice maker thermostat and more. Let me know,Thanks, SeaBreeze b8e6bdd.jpgWHIRLPOOL PRODUCT MANUALS
Sep 26, 2010 | Whirlpool Refrigerators
Water Flow out of freezer compartment
take wires off inlet valve if it stops replace ice maker
Aug 31, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Ice Maker not filling
If your water valve is good and your filter is not in need of replacing then you probable need a new icemaker, yes.
May 12, 2009 | Whirlpool ED2FHEXN Side by Side...
I have a whirlpool gold refrigderator model# GS6NBEXRL00 and the ice maker is not producing any water. I replaced the whole ice maker and nothing happened. After unpluging and plugging the fridge back in...
you p robably have a frozen fill tube for the icemaker. coming inot the rear is a tube for dispensing water into the icemaker. check this for ice if it is frozen you can thaw it out by using a blow dryer to melt theice out. on some models this tube comes thru the back wall of the freezer for cross the freezer icemakers there is a black tube that comes out of the ceiling. if you have any questions please post here and I'll get back to ya thanks Peyton
Mar 06, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Gold icemaker not working Model GD5SHAXLB02
problem with the heater or the thermastat of the ice maker
May 11, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
Apr 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker flooded the house
how much water we talkin here a cup or gallons?? the icemaker will only call for water after dumping cubes,SHOULD at least, if only a cup of water or so id say the ice maker has an issue and needs replacing(its an entire module), there is a valve behind the machine energized by the ice maker, if htat got stuck open in which case water continued to flow overnight i would repalce both ice maker and valve
Mar 01, 2008 | Whirlpool GD5SHAX Side by Side...
Refrigerators Logo
81 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
