Question about Samsung Microwave Ovens
The touch panel pad of my microwave, model Combi, needs replacement. Pl. tell me its cost and the place nearest to Noida where i can get it. Thank you.
  • 1,557 Answers
The cost for a new touch panel is around $80 fitted as i live in australia im not sure of the closest repairer to you but any good electronics repair shop who deal with microwaves can help you look in your local phone directory
p.s the only time we replace touch panels are when they are worn out if the buttons are not responding then the problem is not the touch pad this is a repaly problem but is cheaper to repair have them check as to the correct fault before asking to have the panel replaced
best of luck to you.. please rate this repair thank you
Posted on Aug 02, 2010
My GE Advantium microwave is beeping about 5 times every 2 minutes or so. The display says, "Keypanel Shorted. May need service. Press CLEAR to continue." Ironically, I need a working keypanel to press...
check the touch pad or control unit any short circuit in the control unit, other wise any moisture at control unit chec the circuit other wise replace the touch pad.
Jan 28, 2014 | GE Advantium SCA2000B Microwave Oven
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Starts on own F2 appears
Unplug the oven for few minutes, say 30 minutes and then turn it on.If the problem persists, you need to replace keypad. This is a quite easy repair. You would take the grill off along the top over the door. Once off you should see the screws holding the control panel in place. Remove these screws and remove the control panel. You will now have access to replace the part. Please be aware that the unit stores lethal voltage even when unplugged.
F2 means the touch pad has failed, the manufacturer recommends you replace the touch pad and if this fails to clear the problem replace the control board.The manufacturer recommends this but the problem normally relates to the touch pad. The control board sits just behind the touch pad so is accessible by removing the control panel.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 14, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Pl inform nearest Service Centre of Sujata JuicerMixer located in & around Mayurvihar phase-1, Delhi-91 or in Noida.
If you were to log on to the manufacturer's web site, I think you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 23, 2011 | Microwave Ovens
Control panel not responding properly
this is a costly repair. when the touch pad or control pad is not working normally a new touch pad is required agin it is costly.
Feb 24, 2010 | Whirlpool MH7140XF Microwave Oven
I have a sharp rotisserie(jet convection and grill)oven, it has a big panel which is like a like a touch(not buttons) and now its not working and i cannot operate it, what could be the problem and how much...
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your detailed symptoms.
Feb 09, 2010 | Sharp R-1480 Microwave Oven
F3 code it does nothing
Hello there :
This F-3 code is telling you that your touch pad is bad and needs to be replaced this can be caused by the pad being pressed to hard or that water has got into the touch-pad area and shorted out the electronic side of it this pad can be replaced so you will have to go to your nearest appliance dealer or repair center and see if they can get you pad from there also if you want to order it on line appliance parts pro's .com has these ok
Hope this information is very helpful for you
Best regards Michael
Jan 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
Dec 23, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
107 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
