Question about Kenmore 74602 Gas Dryer
Doesn't get hot enough - Kenmore 74602 Gas Dryer
  • 760 Answers
Check to be sure your dryer vent is free of obstruction. If it doesn't get enough air flow, it will turn off the gas.If that isn't it it could be your thermostat, or gas pressure.
Posted on Aug 02, 2010
Dishes come out feeling gritty. Using Finish doesn't help
If you open the door immediately after the dishes are washed, and before the "dry" cycle, is the water hot enough to have "steam" coming out of the machine?
You should be able to feel the heat.
If not, perhaps the water is not getting hot enough to dissolve the dishwashing powder.
Could you try using a liquid soap once and see what happens?
Be blessed.
Feb 17, 2013 | LG Dishwashers
Kitchen delta faucet doesn't get hot enough
Was it hot enough before the Delta? If so open and close the hot water valve (under the sink) several times as there maybe mineral deposits. I know you said the flow is the same on hot and cold but unless your version is a single handle model the problem should lie with the valve. If this is a cartridge model (cold & Hot together) then the cartridge may be out of align allowing the cold and hot water to mix.
Jan 18, 2018 | Delta & Single Handle Shower Faucet
Startengine gran move doesn't turn when hot
No enough CLEAR information about problem. Please add more detailed info. Thanks
Jul 19, 2012 | Cars & Trucks
Bull bbq doesn't get hot enough?
Try cleaning all the burners they may be block and all the orfices.
Jul 04, 2012 | Bull Texan Grilling
Whirlpool Dryer model LER4624BW2 doesn't get hot enough
What was your solution? I was thinking one or more of the multiple coils in the element could be burned out but not the entire thing I've see that happen before. Glad you got it fixed!
Mar 31, 2012 | Whirlpool Dryers
Car runs great for 10 minutes then shuts off and has to set about an hour before restarting and will only spin over yet has spark and fuel pressure
This sounds like a bad control module, run the car until it dies then remove a sparkplug wire from a sparkplug and stick a screwdriver into it and place it near a ground then have someone spin the key as you watch for spark, if theres no spark then i would say its a bad ignition control module. this is common, when it gets hot is dies out, you can even remove it and have it tested at an auto parts store just make sure they test it a few times to get it hot. good day.
Jun 27, 2011 | 1989 Chevrolet Celebrity
The compressor is running and the fan is running but it is not cooling. The refrigerator runs and stops like normal. Last time we had it checked the repair guy said it was the fan not spinning fast enough...
On the refrigerator and after sometime hold the condenser to see if it is hot, if it doesn't become hot then there is no refrigerant in the system there must be a leakage somewhere or it could be the compressor which is losing compression or doesn't pump well.
May 11, 2011 | Hotpoint RLA50 Refrigerator
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
Kenmore 74602 Gas Dryer Logo
50 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
