Question about Refrigerators
Amana refridgerator i live in harvey, la... after katrina i had to replace my refridgerator. i bought an amana bottom freezer fridge... so far the fan that blows air to the refridgerator has gone out... it was covered under warranty since it was just past the time and the repair man said they used cheap plastic fans from the factory at that time... now the water has stopped in the dispencer and the ice maker... i replaced the filter... which i didn't think was the problem... and as it turns out...it isn't... seems the pump that moves water is either bad or clogged... where is the pump...i have not pulled out the fridge to search for it yet and is it easy to get the part??? any help would be greatly appreciated... this refridgerater is less than 3 yrs old.....thanks... kirk
  • kmdovie Apr 26, 2008
    it looks as if the valve is bad... i was not able to remove the tubing from the valve but checking the voltage ... when you press the despenser button... the voltage goes to 121 on one side... the other side does nothing... i will order the valve and hopefully figure out how to replace the tubing on it....thanks... i really appreciate this... kirk
    Genius:
  • 1,073 Answers
Water valve is in the rear on the right side at the bottom
unbolt it from the ref frame and pull it outward remove the hoses the white plastic ones place a pan under the valve and depress the qater in the door paddle if water comes out of the valve then it is good if no water out of the valve verify the voltage to the valve if 120 to the valve then replace the valve
if no voltage problem lies in the wiring harness or the despensor mech. has a problem
Posted on Apr 25, 2008
Amana fridge abb2222few not cooling but freezer is working where is fan motor located for fridge section
its in the freezer near the top if its not cooling I would check ur air damper flow control, is it to far close or opened? check the cold control thermostat, the thermistors. and of course the fan itself, check door seals.
Mar 17, 2015 | Amana ABB2222FE (22.1 cu. ft.) Bottom...
Why amana fridge ABB1924WES freezer works refridgerator doesn't?
Check for a failed evaporator (cooling coil) fan motor or iced up evaporator due to a failure in the defrost timer, thermostat, or heater.
Jul 26, 2014 | Amana ABB1924WES 19 bottom mount...
Hi there.I have an Amana Side by Side Refridgerator.We are having a problem with the fridge side not cooling enough.The Freezer side is working well.Have you any tips on how to fix it myself ?Cheers.
Check fan which blows cool to fridge compartment is working. Check fridge is defrosted automatically. If not do it manually and check, there will be cooling in fridge compartment. Over frosting will cover up the fan throw behind the freezer. If not auto defrost works, switch off and restart after 5 minutes. Still auto defrost problem, do it manually or replace board.
Jan 27, 2011 | Amana 22.6 cu. ft. Side-By-Side...
The refridgerator is on top and warm, we think the airflow is plugged because the freezer is very cold. How do we get circu- lation? We have emptied the freezer and most of the fridge and have cleaned the...
The access cover for this type of refrigerator is in the refrigerator section, you must remove the screws and the cover will slide out, if the fan motor is not turning or you have ice build up , you need to replace the fan motor, because it is not working properly, a new motor will allow the air to circulate and this should correct the cooling problem.
Nov 12, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refridgerator not cold but freezer working fine
okay this is what you check for, is your freezer back panel covered with ice, if it is then take the panel off and check your heaters for continuity and look at your bimetal thermastat.
another checking point is do you hear the fan running, if not then you need to replace evaporator fan.
Nov 11, 2009 | Amana ABB1927DE Bottom Freezer...
Refridgerator not cooling, but freezer is freezing
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 21, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer working but fan not on in fridge - where to locate fan?
May be ice build up - happened with mine. Had to defrost completely (unplug for 24+ hours) then it worked fine on restarting.
Aug 15, 2009 | Amana ABB1927DE Bottom Freezer...
Amana DBR 2201 CW fridge, freezer good fridge not cooling
sounds like you have a bad evaporator fan motor, located in the freezer section ,it circulates the air up to the refrigerator compartment
Nov 30, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Top Freezer working, Bottom Fridg not.
ice block has formed in the air exchange from the freezer to fridge. Turn off and thaw out, afterwards, check to see if the fan motor is running unobstructed. If problem persists, replace fan motor with new
Aug 10, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
