Question about Panasonic Lumix DMC-TZ3 Digital Camera
My camera is saying this memory card is locked
  • 1,557 Answers
On the side of the memory card the (sd card) there is a very small arm when pushed up it locks the card when down it unlocks it. it nust have been bumped
best luck sir
Posted on Aug 02, 2010
SOURCE: Memory card locked
I just got done fumbling around with the same problem. All you need to do is take the card itself out of camera and there's a mini switch on the side of the card that slides up and down for lock and unlock.
Posted on Oct 04, 2007
abcisme
you have to put a bit of tape around the bit were the little tab use to be.. This works epically if you have lost the tab from the card.
p.s. i did this with an SD card an it worked i don't know if it will work with any other types of card. good luck anywhos, try yahoo answers they seem to have alot of info too. (Y)
Posted on Dec 05, 2007
Bubbabear64
  • 2794 Answers
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
Posted on Jul 04, 2008
There is a tiny button on the side of the card - so small you can hardly see it. Just slide it up and voila All is solved.
It is frustrating as there is nothing in the manual bout this and the onl line assistance wants to charge for 20 seconds advice Mine is free dorothy
Posted on Jun 18, 2009
iwctoys
  • 126 Answers
SOURCE: My camera says card locked
Your memory card has a lock switch, move the switch to unlock.
Posted on Jul 03, 2009
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
Camera saying memory card locked slide lock write psition
The Nikon N75 is a film camera. It doesn't use a memory card at all.
If you're referring to some other digital camera that does use an SD/SDHC card, look at the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 21, 2013 | Nikon Photography
My nikon camera says "Memory
Remove memory card from camera and slide lock in memory card (check photo).
Dec 02, 2010 | Nikon View DX (25243)
My memory card is locked how do i unlock it?
Pull out memory card from camera. on side of card there is a slide switch. The card should say what way to slide to un lock.
Good Luck
Nov 09, 2009 | Samsung BL103 Digital Camera
Cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
Apr 16, 2009 | Nikon D90 Digital Camera with 18-105mm...
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Memory card locked
Jul 04, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera Locked
Many times you need to format the memory card in order to use it... have you formatted the memory card? There's a menu on the camera to do this.
If you're using a card like an SD card, there's a very small slide switch that actually locks the card so no one can over write your pics. Find the slide switch and move it the other way, and that should unlock the card. You'll still have to format.
Mar 18, 2008 | HP Photosmart M425 Digital Camera
How to unlock camera card--HP M525
Little sliding switch on the side of the SD memory card. Remove from camera, slide switch away from lock position, re-install and you should be good to go.
Mar 07, 2008 | Canon PowerShot A530 Digital Camera
Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
107 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
