Question about Sony KP-57WS500 57" Rear Projection Television
I believe the picture bulb is going out, im seeing
I have a sony kp-57ws-500, i believe the picture bulb is going out, im seeing double an triple of every picture but im not real sure i just got the t.v. an was told it needed a hundred dollar part for it so i really dont know please help asap.
  • 1,476 Answers
From your description you have a convergence problem. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to repair it and where to get the parts.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Aug 02, 2010
Dim picture on a sony kp 53s35 53in. projection tv
hello before you buy a bulb have tried the resetting the picture go into the menu on picture setting have half way down it should say reset click it .it should brighten up the screen
regards
sha
Mar 18, 2010 | Sony KP-53S35 53" Rear Projection...
The picture is blurred (double vision) and the picture is also bowed. It appears the bulbs are out of focus. Is this fixable?
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 05, 2009 | Sony KP-53HS20 TV
Double vision on a sony kp-43t90?
you likly have a convergence problem (is that a crt projection TV?)
Sep 18, 2009 | Sony KP-43T90 43" Rear Projection...
I have a sony kp-61xbr300 as no pictures and my stand by light flashes 5 times
sound slike the light bulb has blown , take it out and see if the bulb is black or get the bulb tested. should solve the problem
Jul 06, 2009 | Sony KP-61XBR300 61" Rear Projection...
Picture colors not in phase
Make sure which color is not in line.
What u have said makes me believe U are having a dead vertiacal drive on one of the gun
Rifaa
Nov 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Screen is blury you see double
In order to fix this problem you will need to be able to use a meter and solder well. If you can do these let me know the model number and I will tell you what to check and what to replace. Otherwise you will need to call a repairman and he will charge anywhere form $300-$500 to do the job. Doing it yourself will cost less that $100 Let me know what you would like to do.
Tim Nolan
Sep 12, 2008 | Sony KP-51HW40 51" Rear Projection...
No picture..
hello,,,,,
Picture mute is activated ,it can be vertical amp faulty or one of the c.r.t drive faulty,therefore the mute circuit is active.Increase G2 voltage for the any of the three c.r.t and notice screen .Vertical amp is faultry than you will see horizontal line across the screen and if you see full screen with flyback lines ,means c.r.t drive is having fault.isolate one by one c.r.t drive.
Gopali
Dec 12, 2007 | Sony KP-51HW40 51" Rear Projection...
Double vision
replace the stk ics. they are located inside the tv with lage heat sinks. i do believe sony runs stk392-510. youll have to look at the ics to know which ones for sure.
Oct 04, 2007 | Sony KP-51HW40 51" Rear Projection...
PICTURE PROBLEM!!!
Sep 30, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
146 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
