Question about Sport & Outdoor - Others
I need a turret cap for a Redfield 3/4 4X scope. Help! Rick
SOURCE: Redfield Rifle Scope Manual
I own a Redfield spotting scope the model year is between the 70's to 80's and I need to find a manual for it. But I was Wondering if you could answer a question there is a crossair, then there is another one right above that, then there is a loop on the bottom right hand corner. There is also a yard marker that starts at 600 and goes down to 100. Do you know what it is and how to use it or what the purpose of it is if you could help me that would be great. Thank you for all your help..Joshua Gambler
Posted on Nov 26, 2008
SOURCE: Need to find a Redfield rifle scope repair shop-scope fogs up
iron sight inc.918-445-2001 4814 south elwood avenew tulsa oklahoma. 74107
Posted on Feb 19, 2009
SOURCE: Tasco scope issues with elevation adjustments
Take the lens caps ff.Then run a new Leupold under it..
Posted on Oct 16, 2009
miket756
  • 2702 Answers
SOURCE: I have a 25 year old Redfield 6X18 scope, with an
bullet drop compensation,,,,compleat hog wash!
no such thing in a scope, only a realy pricy one like £1500.00p worth and there not that good! but there coming soon! driven by a lazer for range finding,,,
still your scope has clouded up becouse its leaking
water has got into it, it could be repaired but its not cheap to do, it needs a complet strip down all the class cleand and new seals then a re-gas and it should be as good as new for another 25 years or so,
any good scope with mill dot will work for you, you just need to relurn the bullet drop over again,,and with the years of shooting you have had that should come easy as falling over,,,why not just get a good prised 3/9x40 mill dot and try that out insted, you will be plesently pleased with todays mid priced range scopes treet your self, and save money at the same time
Posted on Nov 20, 2009
Testimonial: "Both Leupold & Nikon DO have bullet drop compensation reticles, which are similar in principal to the mil-dot. The BDC scopes are becoming very popul"
  • 243 Answers
SOURCE: Adjusting Range on Redfield Scope
There should be a set screw or screw that you can loosen to make that adjustment. Once you have it where you like it, just tighten it back up and enjoy you ability to make those quick adjustments when needed.
Posted on Jun 01, 2010
How do you sight in a redfield scope
Your scope should be "in the ball-park" out of the box. This ball park will of course be determined by the height of scope rings you put on your rifle. The taller the scope rings/bases the lower your initial shot... Go to a range or safe outdoor shooting area. Put a large target up at 100 yards, 16"x6" will usually do. Aim at the bulls eye, and click off a round. Use a spotting scope, binoc's or your scope to see where your shot has hit. If it is off the paper and no where to be seen, click off a shot one foot high, check paper, repeat one foot low, one left, one right until you find your shot on paper. Once you find your shot, you will need to adjust the windage (left to right) or elevation (up to down) by using the turrets on the scope. Part of the trick in sighting in your scope is to remember if your shot is high, then you need to crank the turrets in the "up" postion (if it shoots left, turn turrets to the left, and so on). This part is sort of counterintuitive, and may feel foreign. Once you get your scope on paper, continue to adjust until you are hitting consistently 1 inch above bulls at 100 yards. Shooters benches and rifle rests help in this process, but it can also be achieved without. I hope this helps. D
Jul 26, 2014 | Redfield Optics
I have a tasco 3x9x50 world class rifle scope. The scope caps are stuck to the adjustment screws in top and side of scope. I am unable to unscrew the caps without unscrewing the adjustments as well. The...
Try some PB Blaster. Wet a q tip and apply to the area at the base of the turret caps. Wait a few minutes and reapply. Then using a small pair of vice grips attempt to twist the turret covers off. A cotton cloth will help keep the gripping surfaces of the pliers from scratching too bad. Hope this helps.
Jan 20, 2011 | Tasco 3-9x40 World Class Riflescope 30/30...
Need a pair of adjustment caps for a Redfield 2x7 Scope Where might I locate?????
go on line with redfield and look for there tech phone number and call them.
Mar 19, 2010 | Redfield See Thru Rifle Scope Mount Base...
I am looking for an owners manual for a Redfield 6x20x50 Illuminator scope
Contact Leupold, they purchased Redfield.
Here's the info from Redfield's website, hope this helps, Mark the Gunsmith:
When Leupold purchased Redfield in April, 2008, Leupold did not assume the Redfield warranty. Because many Redfield customers have contacted Leupold with regard to the former Redfield warranty, Leupold is making this information available to Redfield optics owners.
At this time, three Redfield repair facilities are available should your Redfield product require service: Parson's Scope Service(513-867-0820), ABO USA Inc (305-859-2010) and Iron Sight Inc. (918-445-2001). The contacts provided are for information purposes only, as these companies are not affiliated with Leupold & Stevens. Please contact them for all information regarding repair, service, and associated charges.
As a courtesy we are now offering 20% off the price of a new Leupold scope, up to $100, in trade for any defective Redfield scope. If you would like to take us up on that offer you may call us at 1-800-LEUPOLD.
Jan 02, 2010 | Redfield Optics
Screw missing in ring that adjust varible power - this screw is a knob that sticks up so you can turn it. i need to find this screw
Here's the info I found on Redfield's website:
Warranty InformationWhen Leupold purchased Redfield in April, 2008, Leupold did not assume the Redfield warranty. Because many Redfield customers have contacted Leupold with regard to the former Redfield warranty, Leupold is making this information available to Redfield optics owners.
Nov 20, 2009 | Optics
I tried to remove adjustment caps from my scope to zero and the entire adjustment assemblies unscrewed.i can not remove cap.
this is what happens when there done up to tight,
get a soft jaw vice and put the thred of the turret into the SOFT JAW VICE!!! (lined with leather),,,,
very gently grip the threds and undo the cap,,,
when refitting the bottom bit to the scope put a small blob of grees on the bearing part,,,oh,,by the way!!,,,
it should be regased! or it could fog up on you when it gets cold,,, only just nip up the turret caps next time
Nov 16, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
Can a novice install a Redfield base and rings?
Problem solved. Redfield had all the size information I needed and mounting the base was a breeze.
Jan 17, 2009 | Redfield See Thru Rifle Scope Mount Base...
Sep 18, 2008 | Redfield Ring and Base Sets for Knight...
Sport & Outdoor - Others Logo
67 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
