Question about WYSE V90LE Thin Client VIA 1.2GHz, 1GB Flash/1GB RAM, PCMCI+SD, US, NIC, XPE Network Terminal
Have a wyse v90l but i don't have admin passwords. how to reset?
Got the v90l off ebay but i don't have admin passwords. how do i reset it to factory defaults?
5 Suggested Answers
  • 25 Answers
SOURCE: Wyse v90l
Best thing to do here is a re-image the client using the tools on the Wyse website.
The new USB imaging tool is pretty handy at imaging this model, and should get this back to a default image and working very quickly :)
Posted on Jul 07, 2009
  • 25 Answers
SOURCE: i have some problem with my monitor frequency and
This is caused by the terminals default display resolution (or the resolution that it was set to in its previous environment). The easiest way to get a display, would be to use a different monitor with a higher range of supported resolutions.
Fingers crossed the previous wnos.ini file would allow a G-key reset. If so, just hold down the G key when the terminal is booting, and it will reset to factory defaults. This might allow your monitor to work. (I think the default resolution is 800x600)
The problem you have is that the terminal might be locked down via the .ini file. So changing the configuration might be difficult. You could use a program like Wireshark to perform a network trace, this would tell you where the terminal is looking for it its wnos.ini file.
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration
  • 3 Answers
SOURCE: WYSE has an admin password that i cant get
the password is Fireport
Posted on Dec 22, 2009
chosen1_39
SOURCE: Wyse S30 resetting to factory defaults
tapping the "G" key upon bootup
Posted on Mar 23, 2010
Wyse z90d7 admin locked Key code
The windows 7 password for Newer Dell/Wyse terminals is "DellCCCvdi"
This is very hard to find on the internet as of right now so i'm putting this here.
Jul 24, 2012 | WYSE Computers & Internet
How to enable the com port
click start control panel admistrative tools computer management device manager scroll to the com port you might see a yellow or red mark
right click select enable or update driver if your computer came with a motherboard disk the drivers could be on it
hope it helps
Apr 16, 2012 | WYSE Winterm V90L Thin Client Desktops...
3com AP 7250 - how do i reset it to factory defaults if i don't have the admin password ?
It will have a reset button on it, hold it down for ten seconds and it should reset the router to factory.
Mar 12, 2012 | 3Com Wireless LAN Access Point 7250...
Schedule task
format ur pc....or go to run command then search .....
Feb 17, 2012 | WYSE V90L Thin Client 1GB Flash/1GB RAM,...
Enter admin mode
I have 10 unit that belonged to Chase back, and it tries to auto connects to there DNS. I tring to reset the unit to factory default with out any success. I have tried just about everything. The remote connect flash don't work because it boot into auto connect with CHASE logo, then fails finding DNS screen. I was able to access the bios, and get into the control panel. I still looking for a way to reset to factory default without success. G, Control+G, Fi report has been used to gain access, but can't change the boot process from logging as CHASE with the auto connect. If you have a solution......
Nov 13, 2010 | WYSE Winterm S30 Network Terminal
How do i reset CMOS setting on V90L
there is a jumper that you remove that says cmos. there should be 3 pins. move the juper to the other side of the 3 pins, turn on the computer, then shut it back off, and put the jumper back to where it was.
May 03, 2010 | WYSE Winterm V90L Thin Client Desktops...
Wyse v90l
Jan 14, 2009 | WYSE V90LE Thin Client VIA 1.2GHz, 1GB...
How to disable auto login on 3235le
Hit the ALT key and F4 while auto logon is counting down to cancel auto logon.
If you've forgotten the admin password you can perform a factory reset by holding down the 'G' key while powering the device on.
Nov 20, 2008 | WYSE Winterm 3235LE (90202401R) PC Desktop
Westell 327W15-06 Modem/router password doesn't work- can we reset?
It's either admin/password or admin/1234. Reset the router to factory specs by holding in the reset tab for thirty seconds.
Aug 20, 2008 | D-Link 802.11g Wireless Router WBR-1310...
WYSE V90LE Thin Client VIA 1.2GHz, 1GB Flash/1GB RAM, PCMCI+SD, US, NIC, XPE  Network Terminal Logo
831 people viewed this question
Top WYSE Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
Edward Greene
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
