Question about HP OfficeJet K80 All-In-One InkJet Printer
When i try to print a document the printer wants to fax
adonscott
  • 106 Answers
SOURCE: printing
hi,
here are the things that i want you to follow to somehow resolve your issue.
1. On your computer, click on start then go to control panel
2. inside control panel open the PRINTERS and FAXES (XP) or PRINTER (VISTA).
3. make sure change the default printer icon to the HP Officejet 5600 series.
- right click HP Officejet 5600 series and choose "set as default printer"
4. then try printing,
note: the reason why you encounter that problem is because the default printer icon is the "HP officejet 5600 series fax".
best regards
adonscott
Posted on Jul 02, 2008
SOURCE: says "document failed to print" constantly after printing half of 1st page
first u check the cable of the printer to system connected properly from both end if not then connect properly , after that problem not solved then change the cable and try if the printer is working then the old cable is faulty , if the printer not ok then uninstall the printer driver from system and restart the system then after restarting the system reinstall the printer driver properly by giving right port, after installing restsrt the system . After restarting the system check by giving a print
Posted on Jun 02, 2009
urbanhookupz
  • 213 Answers
SOURCE: I have a Canon MultiPass 730 multi-function
o.k. I believe I can help you.
Open your file of interest to fax in word, adobe, or text software.
Click file print.
now in your print dialog box make sure your canon MP730fax is selected.
Also, make sure all is bubble clicked for your page range.
click o.k. and a send fax dialog box should appear.
enter recipients info or chose from address book.
Now click send.
It should now fax all pages in that document to the fax you have selected.
You can only send to one recipient at a time with this feature but it should allow you to send all pages in your document.
hope this helps be kind and leave me a testimonial it helps me too.
than ks GOOD LUCK!
Posted on Mar 28, 2010
tbreeze47
  • 3083 Answers
SOURCE: I only want this printer to print documents NOT
There is no way I've heard of to disable the other functions on the printer, except by keeping the machine unplugged from the telephone line. Hope this helps.
Posted on Jun 11, 2010
  • 104 Answers
SOURCE: I have an HP photosmart
Why dont you try uninstalling this form your PC/laptop and reinstalling it again.
This should help restart the printer again.
Good luck and thanks for using Fixya
G.
Posted on Jun 14, 2011
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
Printer does not print from computer. Is in fax mode and I cannot get it out of the fax mode Please help
When you go to print a document and your print window opens you need to change your printer name from Fax to the printer you want to print the document.
Mar 01, 2011 | Office Equipment & Supplies
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
MX310 - faxes in memory. Cartridges have been replaced. Error of low ink remains. What is the key sequence to retrieve these faxes?
Press Fax then Menu. You should see Fax Settings across the top row. Use the left/right arrows to select Memory Reference and press OK. Again use the left/right arrows to select Print Document and press OK. Select the transaction (RX) number of the fax you want to print (received faxes start at 5001) and press OK. Then choose whether you want the first page or the entire fax (yes to first page only or no for the entire fax) and press OK. To print additional faxes repeat from the Select RX number. Print the Memory List to find out which fax is which (from the list that you see under Print Document.
Then you can delete these by selecting Delete Document instead of Print Document in the above directions. Then press OK followed by Yes or No for deleting the document.
Finally press Stop/Reset to leave the menu.
I hope this helps.
Sep 24, 2010 | Canon PIXMA MX310 All-In-One Printer
I want to print a new document but the old document always coming out
This is because - you had tried to print the old documents and that printing sessions were not completed and the documents are in printer buffer. You may switch off the printer - go start - settings - printers and faxes - double click the printer name - you will find some printing requests are there - delete those. Now switch on the printer. Try to print the new document, it will print perfectly. If same thing happen again you do the same steps. But if this problem repeats - you should re-install the operating system.
Jun 12, 2010 | HP DeskJet F4280 All In One Printer InkJet
Check document error when I try to fax a document
You should try a copy to see if it prints OK, when the scanner goes out you sometimes get a black page and your fax machine knows it looks like way too much data.
Jun 15, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Memory full
Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press <Stop/Reset> to clear the error then attempt to print the fax from memory.
  1. Press <FAX>, then press <Menu>. [FAX SETTINGS] will appear at the top row.
  3. Press <OK>.
    1. Press <OK>.
      Press <OK>.
    3. Use[ left.gif] to select <YES> to print the first page only, or use [ right.gif] to select <NO> to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
    4. Press <OK>.
    6. Press <OK>.
    8. Press <OK>.
    9. Use [left.gif ] to select <YES>to delete document, or use [right.gif ] to select <NO> not to delete the document.
    10. Press <OK>. To delete another document, return to step 4g, or to finish deleting, go to step 5.
  1. Press <Stop/Reset>.
Jan 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
HP OfficeJet K80 All-In-One InkJet Printer Logo
81 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
