I have a Canon mx700 printer all in one. When I print photos it keeps printing the same photo over & over again,even though I click it for one photo only.
  • 54 Answers
Check in the printer properties that how many copies you have selected by default
Posted on Apr 25, 2008
Canon iP6600D printer keep printing in Blak ink only
1st option, set the default profile in the printer properties. if it doesnt work. this will change all the settings that you might missed to check to go back to factory setings. also, check if your color cartridge is ok and with enough ink and not dis abled
2nd option, run any 3rd party software that can fix some windows system files or something like that. try to scan pc for viruses
3rd option, reformat your pc. maybe windows files that allows your printer to work are having problems or corrupted, base on the thing that you mentioned that it goes back to the grayscale settings
May 27, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
My MX700 printer tries to send faxes instead of printing page(s).
hi
change your default printer your mx700
1 - start menu
2 - printer and faxes
3 - right click on your printer
not on your fax icon
Jun 09, 2010 | Canon MX700 Office All-In-One InkJet...
Canon MX700 multi-function printer error 5100, double-lines
You can Try
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All best: Pineworks
Jan 02, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
Canon mx700 paper won't go through either feeder
Get good fresh, dry paper. Don't force anything. If you are using photo quality paper, make sure it is right side up.
May 01, 2009 | Canon MX700 Office All-In-One InkJet...
I am getting white horizontal lines through my color photos when I print them. Is there an adjustment that I need to make in order to eliminate these lines for a clear sharp color photograph?
see owners manual PIXMA MX700 Quick Start Guide pages 85-93,:Nozzle Check
Pattern,Print Head Cleaning,Print Head Deep Cleaning and Aligning The Print Head
Mar 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printing too red
At this point I would offer that you bight the bullet and get a set of OEM Canon cartridges and do all the deep cleaning etc and see where that puts you. The third party cartridges may have caused some kind of problem, and not any "damage"
Nov 23, 2008 | Canon MX700 Office All-In-One InkJet...
Printing 4x6 glossy paper photos on Canon MX700
I have a Canon Pixma MX700. I have printed many great photos but not it prints a faint image in the background but the rest of the photo is covered with black ink spots, what can I do to correct this problem?
Nov 09, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon i550 has has rainbow line in output
Even though you say you have ink, the "rainbow" line is usually an ink problem. Try doing a head clean process.
Right-mouse click on the printer and bring up "Properties". There should be a 'Maintenance" tab and one or more cleaning options and/or nozzle checks.
Sep 05, 2008 | Canon BubbleJet i550 InkJet Printer
PHOTO APPEARANCE
Check your printer settings, If your printer is set on draft mode the prints may appear faded washed out, turn up the quality of the printing and this should solve the problem.
Feb 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
57 people viewed this question
k24674
jasbo
jasbo
