Question about JVC UX-GP5 Micro Stereo Audio System Shelf System
How do I stop the demo mode from activating every 3 min after I turn it off?
  • 1,557 Answers
Go into menu and turn of the demo function
good luck.
Posted on Aug 02, 2010
Miele w1913 simulation active on display when I press start/stop
Press and hold the Start/Stop button while switching the unit on with the On/Off switch.
As soon as the Start/Stop illumination ring lights constantly, after approx. 5 sec., release the Start/Stop button.
Immediately press and hold the Start/Stop button until the Demo-Mode is activated, approx. 4 seconds.
Demo-Program deactivation: Follow the instruction for Demo-Mode access above.
Aug 16, 2014 | Washing Machines
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
Nordictrack exp 1000X will only run on pre-programmed
When in Demo Mode, the console will go through a repeating lighting pattern. This mode will only become active when the treadmill is plugged in, the main on/off switch is turned on, and the safety key is not inserted into the console.
The Demo Mode was added to attract attention to the treadmill while it is on display. By default, all treadmills with Demo Mode will come with it turned on. Demo Mode can be turned off at any time.
ethod #1 to switch from the Demo Mode:
1.the STOP button while inserting the safety key tPress and hold o enter the user information mode.
2.Look in the Calories window. When Demo Mode is active, the letter 'd' will appear.
3.Press the SPEED DOWN button to toggle the mode on and off.
4.Once the mode is set as desired, remove the safety key.
Follow the steps and fix it.
God bless you
Jan 18, 2013 | Exercise & Fitness
I have a 2yr old A2550 which just recently started showing only demo information. The belt would not come on nor would the key change the system to manual mode. I used information mode just to see if...
Method #1 to switch from the Demo Mode:Press and hold the STOP button while inserting the safety key to enter the user
information mode.
appear.
May 17, 2011 | Nordic Track NordicTrack Treadmill, A2550
When plug in power cord, set turns on demo mode.No respons when press standby/on butten. By pressing tuner or any function butten, set turns off. What may cause this problem? ingberto@hotmail.com With...
The words "Demo Stop/Clear" are right there on the left-hand control knob.
http://www.p4c.philips.com/files/f/fw-c788_19/fw-c788_19_dfu_eng.pdf
Page 13...
To activate the demonstration
 In Standby mode, press and hold DEMO
STOPçon the system until "DEMO ON" is
displayed.
?žœ The demonstration will begin.
To deactivate the demonstration
 Press and hold DEMO STOP çon the system
until "DEMO OFF" is displayed.
?žœ The system will switch to Standby mode.
Note:
- Even if you remove the AC power cord and
reconnect it to the wall socket, the demonstration
will remain off until you activate it again.
Jan 22, 2011 | Philips FWC788 CD Shelf System
Tv turns off after 7=8 min.
Sometimes they come automatically on demo mode chesk if in your main menu it has a demo mode it may also have a sleep timer st check that also.
Apr 11, 2010 | LG 26LC7DC 26 in. LCD HDTV
Turned off demo mode but it turns back on on its own
Viewing the demonstration (DEMO) mode
The DEMO mode automatically demonstrates several features of
your TV.
To start the DEMO mode:
1. Press MENU.
2. Press left or right button to highlight the SET UP menu.
3. Press up or down button to highlight DEMO.
4. Press left or right button to highlight START.
To stop the DEMO mode:
Press RECALL, EXIT, or POWER.
I hope this helps. Thanks for using fixya.
Jan 20, 2010 | Toshiba 36A43 36" TV
How do i turn offthe demo mode on a philips
On any appliance that has demo mode the solution is usually to hold down the stop button for like 3 seconds.
Sep 23, 2009 | Audio Players & Recorders
How do I turn off Demo mode on Archos 5
Click Tools -> Settings -> Firmware and Plug-Ins and click stop demo Firmware (Mine is not activated and this may not be there).
Jan 31, 2009 | Archos Internet Media Tablet MP3 Player
Toshiba 36inch color tv demo troubleshooting
Demo is activated / de-activated by holding a combination of
two buttons on the tv front for at least four seconds. Try menu &
power or vol up & chan up...........T.
Please rate this solution.......
Oct 28, 2007 | Toshiba 36A43 36" TV
JVC UX-GP5 Micro Stereo Audio System Shelf System Logo
191 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
