Question about Intermatic Inc. ST01C Digital In-Wall Timer
I just purchased the 7-Day Digital In-Wall Timer. The print used in your manual is so tiny that I am unable to read it even with a magnifying glass! Do you have an online version that I can download? Thanks, Jay jayvanc@charter.net
  • 760 Answers
You can download it here. You can select what size you'd like. There also is a quick programming guide on their web site.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/st01c%20-%20english.ashx
Posted on Aug 02, 2010
CAN NOT SET CURRENT TIME AND NEED LARGER PRINT INSTRUCTIONS
You posted under Intermatic ST01C timer.
Open following link to identify timer and see on-line printing that can be enlarged using CTRL key and scroll wheel on mouse.
You can also download the manual in pdf format and use magnifying glass icon on adobe reader to enlarge print
http://waterheatertimer.org/ST01C-program.html
If ST01C is not your timer, resourceful do-it-yourselfer can find links to additional timers on link above, or add a comment with EXACT model number and I will find on-line manual that you can enlarge.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 14, 2011 | Intermatic Inc. ST01C Digital In-Wall...
The instructions are written in tiny writing , I cannot read it. I have a mini digital programmable timer EMT757 please could you help
Looking at the image of the timer, I see your problem and without wanting to sound sarcastic or rude, (and I would probably have to do this as well) could you use a magnifying glass to aid you with the timer. There are times when one must realise one's limitations.
Mar 06, 2011 | Hardware & Accessories
I do not have a question, except that I would like to know why the instructions for your timers are in so small print that even with a magnifying glass they are hard to read.
Fixya does not make timers.
We answer questions.
And you are making a good point.
Who can read those manuals?
If you tell me which timer you have, I might find on-line manual.
Print can be enlarged by clicking on page and then holding down CTRL key on keyboard while rolling mouse wheel.
If you have Utilitec timer.
Here is larger Utilitec manual:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Nov 28, 2010 | RTO Intermatic DT300CL 8.3 Amp Seven Day...
No. I can't read your instructions. They are not clear and so small I cannot see.
ST01C instructions are small ... I want you to go to Intermatic
On right side of page are instruction manuals English, Espanol, etc.
Below those links are EZ instructions.
Choose your instruction page and click link.
To save those instructions to your computer, let page open, then go to File, save as.
Instructions are pdf file ... at top of each pdf is magnifying glass icon for larger print
You can print the page ... go to File, print page
Enlarge pages on internet screen: hold down CTRL key while moving scroll wheel on mouse.
See wiring tips for ST01C
Oct 03, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How do I delete one of the set programs on my utiltech 7-day digital timer? The directions say press the mode key, and keeping it held down, press the program key, it doesn't work. Any suggestions?
Clearing event on Utilitec 7-day timer:
Tiny print on instructions say: press PROG button several times to locate setting you want to clear > Press and hold MODE button > press PROG button to clear setting > to finish, press CLOCK button and display will show time of day.
In case of operational failure:
Tiny print on instructions say: press RESET button to clear all settings >> and then reprogram
Sep 12, 2010 | Intermatic Inc. ST01C Digital In-Wall...
As to 0912773: the manual leaves out many things that one has to know in order to set and use the switch. As it is, the switch doesn't work at all, except as an ordinary manual on/off switch. $25 and...
Tiny print on the instructions is enough to aggravate ya fierce.
You are replacing switch that has 2 wires with a timer that has 4 wires.
1) 5 minutes to Test wires: If your switch has 3 wires, then you have wrong timer. You need Intermatic ST01C or EJ500C. If your switch has 2 wires, then continue: Disconnect both wires from existing switch. Pull them out where you can test with ordinary tester. Power is on. Test each wire from switch to bare copper wire. When test light comes on, that is the hot wire and it is probably Black.
2) 3 minutes to connect wires:
Timer black wire goes to hot wire which is probably black
Timer red (or blue) wire goes to other wire that was connected to switch
Timer white wire connects with other white wires that are held together with a wire nut and pushed to back of box. [If box does not contain other wires, connect Timer white wire to bare ground wire.]
Timer green wire connects to bare ground wire
3) 5 more hours to program timer
Tiny print shows 5 steps for programming timer. Write the steps out so you can see them clearly. Drink a glass of water. And pull a chair in front of timer to set 7 on and 7 off programs. It will work fine.
Aug 24, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I want to reprogram my timer to a new on time,and off time. do i have to clear the existing program,and start from scratch? if yes, do i use 6a an on/off program at specific times. next question: ...
To reprogram times, it might be easier to clear all programs. Read the manual. Sometimes you have to read it several times. Or scan it into computer so you can see print larger. Or go to manufacturer website and download manual. Some manuals are impossible to find, some have unclear instructions.
For programming help. Post brand and model number of timer so product is identified. Some products have nearly identical numbers but are very different. It's a zoo of products. So be specific.
Timers generally repeat 1 week or 1 day. Do you have a in-wall timer? Or box-type timer
Intermatic in-wall EJ500, ST01C, EI600 offer Daylight Savings & Dusk to Dawn operations. EI600 has 5 year warranty. Other two have 1 year warranty.
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%207-day%20astro%20time%20switches.aspx
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
Click product number to see manual. Download manual to your computer> go to File at top of browser, click 'save' -or- click 'print'
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If you have a boxtype timer, Intermatic makes timer with photoelectric sensor
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
Aug 14, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
I can not read the insturction book.. How do i see the watch in the dark? and set the timer?
mcdevito75 here, Best Bet, any Dollar store will carry magnifying glass, I use one myself, for reading very fine print as in your watches instruction manual.
Jul 07, 2010 | Casio Watches
Intermatic Inc. ST01C Digital In-Wall Timer Logo
148 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
