Question about Daewoo Televison & Video
I have an Apex televsion, model no. AT3208S. My remote control buttons are not working correctly...nor are the buttons on the front panel of my TV. I can turn up the volume but can not turn down the volume. The volume on my TV is so loud now that it has beyond comfortable; thus, i have to keep the TV on mute. Is there a way to re-set the TV and/or remote control to factory settings in hopes of rectifying the problem.? I've tried re-programming the remote control per the on-line manual, but I can't even get the remote to respond to that. Any suggestions would be appreciated.
  • 49 Answers
IT is not available in the elect market,soyou connect one set topbox through audio/video input socket then you can change with the help of set top box remote.
Posted on Aug 02, 2010
Apex model #AT2704S front panel buttons stop working? Menu, channels, volume, and power? Also has a red key in lower left corner and the screen is blue. I have tried mute and function buttons on univ
Your Apex TV has been locked by anyway. Just try this method to unlock it.
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Feb 07, 2013 | Apex Digital Televison & Video
Problem with code for apex ld3249
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 07, 2010 | Apex Digital LD3249 LCD TV
Cannot use comcast remote for volume or to turn off apex 32" at3208s
See http://www.comcast.com/corporate/customers/customer_support/remotes.html
Feb 13, 2010 | Apex Digital AT3208S 32" TV
Apex AT3208s not switch on TV.Light diode red glow.
AT3208s 32" will not turn on have good power supply.
Apr 19, 2009 | Apex Digital AT3208S 32" TV
I have a APEX AT3208S 32" TV and I just subscribed to Direct TV, when I programmed my remote to the Direct TV, i have to use 2 remotes, one to turn the tv on and go to Video 3 and the other to switch...
The direct tv remote will control all of your electroincs set that one up for all of your needs ...codes for tvs in the direct tv book! make sure you change the selection on the remote!
Dec 06, 2008 | Apex Digital AT3208S 32" TV
My tv/jcv (i have no clue of type) keeps zooming
Take your remote control, press volume to 0
Press the mute button on your remote, at the same time, press the menu button on your TV for 3 seconds.
A menu will apear, press the right arrow on your remote to go to menu 002 to fix your problem.
Oct 28, 2008 | Apex Digital AT3208S 32" TV
Where do I find APEX parts? 32" PF3225 sound card
Hallo,
I have a Apex Sound Card.
If you need it send me a mail.
Mar 14, 2008 | Apex Digital AT3208S 32" TV
Loss of Picture on Right and left side
gbr@yahoo.com
Jan 02, 2008 | Apex Digital AT3208S 32" TV
Finding a code
What is the model number of the Apex TV you are using this remote for?
The CK5G-C1 remote was supplied only with model AT3208S TV. It will require no code when used with that model. If trying to use it with any other model TV, you can try the other Apex TV codes found in the AT3208s user's manual that can be found in .pdf format at : http://www.apexdigitalinc.com/manual/AT3208S.pdf
Let me know if this helps, or I can be of further help.
In any case, good luck!
Oct 22, 2007 | Apex Digital PF3220 32" TV
Televison & Video Logo
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
