Is any one familiar with Onyx Production house software?? These are the issues I am having: Software Version: RIP-Queue 6.00 6.00 Release 12/10/2003 Build 6774 1) Black and White - Photographs come out with a green or blue hue. Used to come out the proper grey color then suddenly started being printed with a green tint and sometimes a deep blue tint. 2) Green tint on some color photos, with skin color also turning green. 3)Color Photos are very pale, not vibrant. Type of paper we use: Canvas Paper
  • yan dikshteyn Aug 02, 2010
    We have done all of this I need software or color management help using Onyx production House Printing software
  • 4,924 Answers
This sounds to me like a setting mess up ...Try to reset the printer from the main menu ..to the original defaults ...This will probably be present like a feature in the menu ..or by turning it down and keep the power button pressed for few seconds no less then 5 when you start it again ...Unplug it also when you shut it down ..this in case it is a printer with not that complicated menu ..
Another thing to do in order to avoid any software settings that causes this issue ..is to reinstall the software you use for printing ,,and the driver for the communication between the printer and the computer ...This way you will be sure that all the settings are on default values..and any issue that may persist will be on a physical nature...
Posted on Aug 02, 2010
  • Catalin Turcu
    Catalin Turcu Aug 02, 2010
    Like I said ..if there is something wrong with the software ..and you do not know what you might set wrong ..the quick fix is to uninstall the software ...and reinstall it clean ...This meaning remove the software from the add remove software in the control panel ...and after that go to my computer folder...than into C drive ..and program files folder..in there remove(delete ) the folder of the program if there is any left ...cause it may keep the settings in that folder and resume them when you reinstall ...This way reinstalling the Onyx software ..you will have it on default settings ..and if the problem is from there it will be solved...
SET UP PROBLEM
SOFTWARE/FIRMWARE required to work.
Drivers
PC: Windows XP SP3 to Windows 8
Mac: OS X 10.5 to OS X 10.10
Have a look here;
Onyx Series Production Mixers Mackie
Jul 15, 2017 | Mackie Onyx 1640i Mixer
Activation code diye hocce na
need hardware key for onyx rip center ver 7 for hp 8000s
Jan 05, 2014 | Microsoft Office 2010
My onyx postershop 7 dongal lost
on installing I am facing problem (hardware key)
May 02, 2011 | Onyx PosterShop 7 for Windows Full Version...
HP Designjet z6100 printing wrong size _Example: a 400mm x 400mm print ends up coming out at 400mm x 395mm
I had the same problem maybe this will help
Problems also may occured when you rotate your file in "Printhouse"
You should make the rotation before you rip your file.
(1) "HP z6100 Banding / Print Lock Up / Length Issues"
Symptoms:
Customers using HP DesignJet z6100 with firmware version 6 and the ONYX v 7.1 HP Driver may experience banding, printer locking, and printing length issues.
Cause:
The problem is caused by the varware data written to the HP z6100 hard drive.
Workaround:
If you experience any of the issues listed above, please contact HP Tech Support. They may need to do a Disk Wipe and should only be done under the guidance of a licensed HP Technician.
(2) "I'm experiencing inconsistent print lengths. Why?"
This issue is not RIP related. Check below for workarounds with various printers.
For HPs
On your HP's printer menu, set "Extended Margins". This should resolve the inconsistent print length.
For Encads
Onyx users who have Encads have recommended the following:
* Configure the X axis in the setup menu.
* Be sure to save your settings as "User 1" (without saving the settings, they disappear when you power down the printer).
* If produced in-house, add bleed to the image.
* If produced by someone else, print the image at 101% to bump up the finished size.
* Static and slippage can cause the issue.
* Canvas media almost always shrinks about 1/4 inch per 4 feet due to moisture and weave of the media.
* Talk to Encad -- they have a worksheet that explains how to best reduce the problem.
For all others
Most major inkjet printer manufacturers say that .5" on an 86" print falls within what they deem "acceptable". If your printer has Media Feed Calibration or some other feed mechanism calibration, be sure to do it... and frequently.
Description: HP Z6100 having issues with print length. Discussed firmware versions and extended margins setting on printer
Please feel free to contact us if you have any questions regarding this solution or this case. Be sure to reference the case ID
Feb 17, 2011 | HP Designjet Z6100 InkJet Printer
This is tha new version is coming
ProCoder 3The Ultimate Format Converter Our ProCoder® 3 software combines speed and flexibility into a streamlined video conversion tool. Widely acknowledged as the leading software transcoder, it features extensive input/output options, advanced filtering, batch processing, and an easy-to-use interface.
Whether encoding MPEG video for DVD production, producing Windows Media for streaming or transcoding between NTSC and PAL, ProCoder software makes video format conversion quick and easy. With it you can encode a single source to multiple targets simultaneously, run multiple conversion jobs back-to-back in batch mode, or use drag-and-drop preset icons to start conversion with a single click.
The ProCoder 3 software has an array of high-performance features, including a design that efficiently leverages the power of your CPU, broad codec support, local and networked use capabilities to fit your workflow, and queue management to ensure your jobs are performed in just the right order.
Dec 30, 2010 | Canopus ProCoder Express
When i got my rca mp3 the easy rip software was able to open.
If you have upgrade your computer after it was busted, that could cause your old version of the easy rip software to not recognize your rca mp3. what you'll prob need to do is update the easy rip software.
Aug 17, 2009 | RCA M4208 MP3 Player
No Rip print software for my Epson 1290
Restore your MAC to an earlier OS with your Time Machine backup.
Apr 16, 2017 | Epson Stylus Office Equipment & Supplies
How to do rip and hold for 1r400
NO.
Command Workstation Use For Xerox Not For Canon. OK
Dec 12, 2008 | Canon imageRUNNER 400S Copier
135 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
