Question about Maytag Neptune MDE5500AY Electric Dryer
We had to replace the wheel inside the dryer and my husband cannot figure out how to put it back on...any help is well needed....thank you!!
  • Maytag Master
  • 3,053 Answers
Hello kaykayI was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
    Problem Solver:
  • 29 Answers
The brands are all different without that it is hard to tell you exactly what to do
Posted on Nov 26, 2011
I can't remember ever seeing a light inside my dryer, but my husband thinks we need a new bulb.
Hello Michelle, thank you for your inquiry!
I understand that you are unsure if your Frigidaire dryer, AEQ6000ES2, has a light inside of it. I have researched your dryer and it does have a light inside of it. The part number for the light is 131843500. Unfortunately there are not instructions on how to replace the light. We would recommend contacting a professional technician for proper repair and replacement of the light bulb. I hope this information is helpful to you. -Matt
Dec 06, 2015 | Frigidaire Dryers
Any help with reconnecting wires to heating element?
I would only be guessing but it was probably done wrong
Jul 14, 2014 | Roper Dryers
We have a Maytag legacy series sde515dayw. We push the start button and it will not turn on. Do we need to replace a fuse or reset a button? The light is on when we open the door and we checked the door...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 21, 2011 | Dryers
I took the bladeoff to oil and now can't remember how to get it back together.
i needed to replace my blade - my husband replaced it but it would not cut so we took it apart and cant figure out how to put it back together. nothing helpful on line.
did anyone have a link how to put all the pieces back together to create the blade? thanks
Jan 16, 2011 | Oster 76076-010 Hair Trimmer
Can't remove motor from Whirlpool dryer (LER3624EQ1)
no set screw,,,put the motor back,,,put the motor clip back on...lock it back down...ok now take a wrench and put it on the end of the motor where the belt goes,,if your by your sef,,prop the wrench againt the inner cabnit wall,,,than turn the blower wheel its hard but it will come off you..just lock that motor shaft down,,grip pliers..wracket,,,please use glovers to turn blower wheel..housing is very sharp..onthejob
Jan 24, 2009 | Whirlpool LER4634J Electric Dryer
Can't Put Belt On
You have to remove the front of the dryer to
access the drum. First unplug the dryer.There are screws at the bottom of the front to remove the lower section. Once you remove that you can get to the screws for the door section. The front of the drum rides on the inside of the front panel so when you remove the panel the drum will drop down. Try to keep the drum in place with something to hold it up. Remove the old belt and place the new belt around the drum. Slid the belt back to where the belt used to ride and then loop the belt around the motor and the tension wheel. Make sure the tension wheel is tightening the belt. Hold up the drum and put the front panel back on. You may need a helper to hold things while you do this. Rotate the drum by hand and make sure it moves smoothly. Plug it back in and give it a try. I hope this helps. Any questions feel free to ask. Please rate me so I know if I'm Helping. Thanks.
Dec 30, 2008 | Frigidaire FEQ1442ES Electric Dryer
Brown streaks on clothes from dryer
is it possible that something was left in a pocket that ended up in the dryer check inside the dryer for any ink gum or stains inside the drum because there is no way the dryer left these stains other than from something you accidentally put inside
Feb 16, 2018 | Maytag Dryers
Frigidaire Affinity Dryer
try hitting stop clear twice check the door switch see if its working also if you didnt send in your warrenty card then frigidaire dont know when you bought it if youve never had it serviced i was a factory tech for years for frigidaire so you can call them and say you bought it say a week from now and get it serviced let me know what happens
May 17, 2008 | Dryers
Whirlpool stacked washer dryer LTE 5243DQ6
Open dryer door, and reach up to the top of drum and push on it very gently. If it moves more than 1/4 inch or more, the dryer guides needs to be replaced. Sadly the guides are for front and rear so that means the drum has to be removed and the guides in the rear has to be changed first.
It will involve some time so be very careful! Another thing is to check for the dryer idler arm pully. if this pully is squealing/worn out, it will also need to be replaced at the same time you replace the guides.
My suggestion is to call your contractor and make them come out to see if they damaged it. Your local appliance repair store can also sometimes help.
May 16, 2008 | Whirlpool LTE5243D Top Load Stacked...
Maytag Neptune MDE5500AY Electric Dryer Logo
270 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
