Question about GE Profile Harmony DPGT750EC Electric Dryer
MY OLD GE ELECTRIC DRYER TURNS ON BUT WILL NOT HEAT
    President:
  • 1,382 Answers
Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Thank you
Posted on Aug 02, 2010
Old dryer turns but does not heat, so bought a new one the same thing happens, can it be the electric plug?
A plug is easy to change, You can do it your self, Just make shure you turn your breaker off, Before you remove the old plug,Follow the wires on the old plug, End connect them to the same terminals on the new plug.Allso you can Write it down where they go,Before you disconect the wires from the old plug, Try the cheap route first, End that is to replace the old plug,
Oct 18, 2012 | GE GTDP490EDWS 7.0 cu. ft. duradrum...
DRYER DRUM TURNS BUT NO HEAT. MANUAL MENTIONS FUSE BUT UNABLE TO LOCATE WHERE FUSE MAY BE
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 24, 2011 | GE Profile Harmony DPGT750EC Electric...
Drum turns but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 21, 2010 | GE DBXR463EDWW Electric Dryer
What part is needed to fix the dryer when there is
if it's a gas dryer probably an ignitor. electric dryer, the element.
May 22, 2010 | GE Profile Harmony DPGT750EC Electric...
The drum turns but there is no heat
Get a new heating element if you wish your machine to continue performing.
Apr 18, 2010 | GE Profile DPSB620ECWW Electric Dryer
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
Dryer drum turns but no heat. Checked fuses and
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
879hftg
Sep 27, 2009 | GE Profile Harmony DPGT750EC Electric...
New Dryer, drum turns but no heat.
Check your breaker. Reset it.
Apr 22, 2009 | Dryers
GE Profile Harmony DPGT750EC Electric Dryer Logo
162 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
