Question about Maxent MX-50X3 50 in. HD-Ready Plasma Television
Coax antenna to Maxent TV
My antenna has a coax-my 50 in Maxent mx50X3 has no coax hook up, so i connect antenna coax to DVD and connect DVD S-Video cable to TV, but I can't scan the TV channel?
Pleas help?
2 Suggested Answers
  • 864 Answers
SOURCE: My antenna has a coax-my 50 in Maxent mx50X3 has no coax hook up
That unit does not have a tuner so it does not have an antenna input. You need to connect a cable box, satellite box, VCR with a digital tuner (or an additional DTV box for converted input), or DVR to one of the HDMI, S-Video, or Component inputs to view TV.
Posted on Oct 26, 2009
How do I connect the coax antenna cable?
This unit doesn't have a tuner, This is what I found when researching this question for you.Maybe you can hookup DVD player or VCR player with audio and video cables, I know some VCR's have HDMI on them too that can be hooked on that TV. Good Luck
Apr 26, 2015 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Can you turn coax into rca cables since the maxent I have doesnt have a coax input
You can but the connection type is not the problem. If you have Coax cable or antenna type signal you need to put that into a tuner capable of providing the RCA (baseband or composite) video out with RCA audio as well. However if one is going that route with a HD display then the SVHS tyoe connector or even HDMI or some component level cables should be used to get the full benefit of the HD signal.
If your HDTV has no Coax input then it is not a TV but a display
device more like what is used in computers.
Aug 09, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
I am having problems programing my Maxent MX50X3 TV to our Direct TV system.
Hi, Your Direct TV system runs on channel 3 or 4 on the Maxent HDTV and the decoder box(PVR) works all the channels. So you might not be able to program your HDTV. Good luck.
Jun 14, 2011 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
Is there any way to connect basic cable to the tv without using a converter box or anything else
Recently, I dropped HBO with my cable company and there dont have a box. Since the Maxent 42 is only a monitor and doesnot have a tuner...there is no where to plug cable from the wall to the tv.
Solution...plug cable from wall to VCR/DVD and then use RCA cables (Red,White and Yellow cables) from output from VCR/DVD. works great.
Nov 22, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
My antenna has a coax-my 50 in Maxent mx50X3 has no coax hook up. How do I connect these two?
Oct 26, 2009 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Trying to hook up your DV220SL8 DVD/CD Video Cassette Recorder. I have an antenna coming in coax but there are no places to plug any of the jacks on the tv.
There are two ways of solving this problem
1.It seems to me that you need an RF Modulator Box. What this does is convert the RCA cables (Yellow,White,Red cables) into coax. You buy the box then plug you antenna and RCA cables into the box. The box has a coax output that goes to your TV. You can then switch from VCR\DVD to antenna.
2. I dont know if your VCR/DVD has it but try hooking up your antenna to the VCR coax INPUT and then hook up your TV to the coax OUTPUT. Both Coax INPUT and Coax OUTPUT should be on the back of the VCR/DVD device. Your going to need an extra Coax wire for this.
Hope this helps
Thanks for reading!
hope this helps
May 01, 2008 | Televison & Video
Hook up vcr
yes, you need to use an Audio/Video cable (red, white, yellow) to hook to the TV. I've never seen a VCR that doesn't have coax connectors for the antenna input and TV ouput, but maybe the new ones are starting to leave that out. Normally, you run the antenna or cable coax into the VCR's input, then run another coax from the VCR output to the TV's input (or use an A/V cable)
Dec 20, 2007 | Sharp VC-A420U VHS VCR
Maxent MX50X3 HDMI input
I had the same problem and found that the ground wire outside where the cable companys box is was not even hooked up. It was just hanging there, once I hooked it up it went away. The cable company gave me the run around telling me it wasn't their fault. I now have Direct Tv.
Dec 04, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Maxent MX-50X3 50 in. HD-Ready Plasma Television Logo
636 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
