Question about Motorola Mobility H350 Wireless Headset
Bluetooth and new phone
How do i find the pairing code
  • Anonymous Jul 13, 2008
    My H350 was paired with my I Phone. It worked great.
    The IPhone was replaced and the new one will not pair.I
  • jmacintyre Jul 14, 2008
    I have a LG Venus and can't get my motorola350 to work. I have it showing up in my phone but I don't get to any step that says pair. I have both peices turned on. and I highlight the motorola 350 and hit okay and it says connnecitng but then it says its either too far or something else.
Posted on May 07, 2008
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
What is the passcode for vh300 bluetooth sony ericsson?
Accessory instructions: VH300 Before you can use your Bluetooth
Aug 18, 2010 | Sony Ericsson VH300 Bluetooth Mono...
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    Aug 04, 2010 | Apple iPhone Smartphone
    Need to re-pair bluetooth to phone
    Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
    Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
    Plantronics 2XX pair code
    The pairing pin should be 0000, most bluetooth device's use all 0's.
    Hope this help's.
    Apr 17, 2009 | Plantronics Explorer 220 Bluetooth Headset...
    Bh 101 bluetooth headset lost manual and forgot pairing code
    Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
    Apr 14, 2009 | Cell Phones
    Bluetooth Pairing code
    pairing code or pass word for my plantronics220 bluetooth ear piece
    Mar 12, 2009 | Plantronics Explorer 220 Bluetooth Headset...
    Pairing to bluetooth
    The V3C cant pair with other phones.. I have to hold my bluetooth head set on top of my phone to get it to pair sometimes and make sure the headset is in pairing mode
    Nov 09, 2007 | Motorola Mobility RAZR V3c Cellular Phone
    Motorola Mobility H350 Wireless Headset Logo
    125 people viewed this question
    Top Motorola Mobility Radio Communications Experts
    Lawrence Oravetz
    Dennis
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
