Question about Goodman Heating & Cooling
Goodman Model #GSC130361DE Fan go on and off after
Fan go on and off after 5 minutes of running
4 Suggested Answers
  • 79 Answers
SOURCE: Goodman GSC130361DE premature shut off
im not sure what tstat you have? if you still have your tstat book it well tell you how to set it up. may be it was not programed when installed. i hope that helps
Posted on Apr 12, 2010
kingbrizzle
  • 407 Answers
SOURCE: I have a Goodman GSC130361DE it is too small for a 2100sq ft home
Both companies can be right at the same time and I will explain this. You have a 3 ton system, going by the model number you have given. For every 1 ton of air, you get an average of 400 cfm. That is 1200 cfm for your system. You need an average of 1 cfm per square foot, that's the basic way to calculate a residential system. So, if your house is 2100 sq ft, you need at least 2100 cfms, which is a 5 ton unit. That is were the company that says it's to small gets there diagnosis, on the other hand, with a unit that is to small, it can still operate the way it's supposed to and the company that says it's fine is probably going off of the way the unit is ''technically'' working. Things to consider though before you come to an conclusion, when you say that your house is 2100 sq ft, the unit only needs to be based on square footage of "living space". The best way to do this is to go to each room where there is a supply register and get the sq ft of each room, it might be smaller than 2100 sq ft. A lot of people, when selling a home, will include the garage and other "non living" spaces in the square footage. Other things to consider are the heat loads of each room, meaning how many windows, doors, etc. Depending on the heat loads, the placement of the registers, and your duct work, you can have the right sized system and still not get the performance it's meant to have. The problem still remains that your not happy with the system's performance and that's the important thing, unfortunately, it might be a lot bigger of a problem than you thought. Hope this helps and good luck!
Posted on Jul 17, 2010
shastalaker7
  • 1515 Answers
SOURCE: My Goodman GSC130361DE 60 Htz has problem with
Hi, I am assuming you are talking about the indoor coil icing up when you are in cooling. The reason I am asking this as this appears to be a heat-pump and they will ice up in the winter at the outdoor unit. I will go with the indoor coil. If the indoor fan is blowing up to speed and you have cleaned the indoor coil but still have this ice forming, it could very well be that you are low on freon. This will also cause the suction line, the large copper line outdoors to ice and on into the indoor coil. This will happen if you have developed a leak some where. Also, make sure you have good strong return air coming back through the air filter, because if you have problems with the duct work like holes from varments, or you have had any repairman around the duct work, sometimes they will flatten it causing no air flow and you will have ice. My bet is you are low on gas. Shut the unit off to make sure it has no ice on the coil, and go to the outdoor unit. Have someone turn it to cooling and put your hand above the fan on the condenser coil. The air should start to get warm and then hot if the freon level is ok. This also depends on the outdoor temperatures. The hotter it is outdoors, the hotter the air will be. If it is rather cool, around lets say 75*F, and this copper suction line is starting to form ice, the problem is it is low on freon. In this case, this is something you will need to call a tech out to charge the unit. You have to be certified and be able to buy the right freon which is only available to a/c and refrigeration tech's. If this is a heat -pump, and it is winter where you are and the outdoor coil is icing up, let me know and I can go through the steps to check this out. I do believe this is a summer problem where you may be, but you never know unless you ask. Please don't forget to rate me on this post as I am sure you will be kind. I wish I could save you a tech call, but if its low and you have cleaned the indoor coils, and filter is clean, then this is the problem.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Sep 26, 2010
I have a Goodman model # CK30-10.. The fan on the outside unit runs sometimes. I notice when I first turn the unit on, the fan will run 5 to 10 minutes and then shutoff. Is this a capacitor or relay?
Not a relay. It is probably the capacitor. Also may be that the motor bearings are dry and the motor will need to be replaced. Its always less expensive to try the capacitor. Certainly work safe when it comes to run capacitors!
Jun 25, 2015 | Goodman Heating & Cooling
After one heat cycle, the blower motor keeps running, even after cool down is complete. The furnace will not refire until i turn off the power and wait about 20 minutes for a reset.
your limit switch is opening up, that causes constant fan. Check for flashing codes after flame shuts off and fan continues. Check airflow, filters, lack on return air for possible hi temp limit problems.
Nov 17, 2011 | Goodman Heating & Cooling
Hi I have a goodman MSG-18HWN1 heating and cooling mini-split unit. The unit keeps going on and off on a cycle of about 5 minutes. 5 minute, unit not started, unit starts for about 5 minutes, stops for...
Due to abnormal temp of out door.Check outdoor fan motor and compressor and also sensor.
Fan motor not working- rectify/replace fan capacitor.
Sensor defective-Replace it
Compressor high amps-Replace running capacitor.
Sensor misplaced or defective-Place correctly or replace it.
Jan 05, 2011 | Heating & Cooling
Apr 06, 2010 | Goodman CLQ30AR32 Air Conditioner
Model #GMPN100-4 Goodman furnace. Vent fan
The sequence of events for furnace operation is -
Fan purge for 30-45 seconds. During this time, a pressure switch is actuated by the running of the purge fan, proving the control board the purge fan is running.
After purge and purge prove, the hot surface ignition and or spark begins. After a few second delay, the gas valve will open. The control board then monitors for flame prove through another sensor located near the burners. If there is no flame within 3-5 seconds, the gas valve closes. It will repeat this process, usually 3 times, before it shuts the system down, which requires a power down of the system to reset.
I have seen trash get into the hose between the purge blower and the purge switch. But you could be having other problems.
Dec 17, 2009 | Goodman Heating & Cooling
Goodman model 135-5 furnace fan and induce motor run all time even with thermostat off. Theermostat and wire were replace
Is there a thermal Fan/Limit switch in this furnace? If so you may need to tweak the low range setting so it can turn off the blower.
Nov 04, 2009 | Goodman GMS90703BXA Heater
Fan not running on Heat Pum
That does not sound normal at all, I have a Goodman Heatpump and the Fan on the Evaporator (outside unit) should run as soon as it starts up!
The only delay you should be seeing is when the unit starts, the fan in the AHU starts 5 seconds after and runs for about 1.5 minutes after shutdown.
Sep 19, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
74 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
