Question about Sony KDF-E50A10 50 in. LCD HDTV
Kepslosing picture then turns off then turns on
Keeps losing picture then turns off then turns on again.
  • 10,594 Answers
Replace lamp if it has not been replaced in last 2-3 years as existing lamp is dying and causing that problem.
Lamp replacement procedure is easy and written in user manual of tv.
Let me know if you have additional question.
Posted on Aug 02, 2010
How do I repair our Samsung LCD Television? I would really appreciate an answer ASAP. Where will my answer appear for my review.
Don't know what service provider you have, free to air, satellite, cable or what? Try feeding the TV another signal and see what it does. Play recorder movie from DVD, or if you have a VCR around even try that. If it plays the DVD etc, with no issues, then TV is not the problem, most likely the cable box, satellite box etc, could be as simple as a bad cable connection at the house, a splitter or street box. Eliminate all the simple things first, then look at the TV.
Mar 04, 2015 | Samsung Televison & Video
My 36'' Toshiba televisions picture keeps going fuzzy then if you turn it off and on the picture comes back on. Also when watching movies we lose the picture but hear the sound. Once again if I turn off...
I would start with the Tcon but the main would do this as well, along with the power board...test the voltages coming from the ps board when its giving issues and see if they are ok, if they are try the tcon board
Dec 11, 2017 | Toshiba 36A40 36" TV
My tv keeps losing the picture, i can still hear the sound but no picture after i turn it off for a few minutes it will come on again.
Overheated semiconductor circuit. Maybe due to moisture condensation. Use a fan to cool the back of the tv?
Nov 05, 2010 | Samsung 933HD+1 19 in. TV
Television keeps losing its picture quality and turns itself off.
your T-Con board is failing you need a tech to replace it
Nov 18, 2009 | Televison & Video
I lose the picture after 20 - 25 mins. I turn off the TV and turn it quickly back on and the picture works fine; then 10 - 15 mins goes by and I lose the picture again. I turn the TV off then quickly back...
it probablt needs power supply capacitors, if you can take it apart and inspect the power supply, the bad capacitors usually are expanded and have a bulge at the top, you would need to solder these parts in, so some skill is required.
Sep 07, 2009 | Polaroid FLM-4201 42 in. LCD Television
Have picture lose picture tv turns off and on
the lamp has a life cicle. if yours is been used a lot. then the lamp has to be changed. when the tv cannot turn on steady and gets off imm. the computer inside the tv tries to turn off the set but the lamp charges again and the micro tends to keep working. the first step to take in this tv is to change the lamp to eliminate this common source of problems
Jan 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
Dec 01, 2008 | LG RU-52SZ30 52" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
TV will lose picture then go into standby!
Yes it is a temp problem as you found out for your self Great call on that BUD.. the best thing to do is contact sharp to see if they have had simular problems and if there are any recalls on this model . If not they will instruct you where to send the monitor into to be fixed.
Mar 31, 2006 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sony KDF-E50A10 50 in. LCD HDTV Logo
819 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
