Question about Cub Cadet Garden
Cub cadet oil changing? Every when? - Cub Cadet Garden
  • 252 Answers
General rule is to change oil every 50 hrs and even more frequently if used in hot / dusty conditions or with heavy loads , check oil before each mow , and clean air filter every 25 hr
change oil filter every 2nd oil change at least
cheers paul
Posted on Aug 02, 2010
My 04 cub cadet m60 tank with a 27hp Koehler just up and quits after 20 min. I just changed oil and filter and "change oil " is blinking. Help
I'm not a Cub dealer but the "change oil" light should reset itself after usually an hour of use. check the oil level for the no start. if it has an oil level switch and is low, there will be no spark.
Jun 01, 2016 | Cub Cadet Garden
What type of oil do i use
(32 degrees and above, 30w oil) - (32 degrees to 0 degrees, 10w-30) - (32 degrees to -20 degrees below 0 and beyond -20, 5w-20 or 5w-30) Cub Cadets call for a low ash oil. it can be purchased at any cub cadet tractor dealership.
Jan 21, 2016 | Cub Cadet Snow Blowers. 28 in. Two-Stage...
2015 Cub Cadet XT2. Where can I get a manual?
There is a Cub Cadet App that lets you connect to your Cadet and monitor status, like oil change due etc. It also has built in manual. Check it out
http://www.cubcadet.com/equipment/CubCadetFullPageArticleDisplayView?langId=-1&storeId=10051&catalogId=14101&pageView=Cubcadet_General/CubConnect.html
Aug 07, 2015 | Cub Cadet Garden
HOW TO RESET THE BLINKING OIL LIGHT ON A CUB CADET RZT
The dashboard for Cub Cadet/MTD mowers includes hour meter, Low oil, or time for oil change, PTO, and other lights. If the oil light is flashing, it means 1 of 2 things. Low Oil Level, or it is time to perform maintenance by changing Oil and Filter. After this process, the light will reset itself after a few more hours of running.
Sep 08, 2014 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
Cub cadet troubleshooting
unhook battery wait 20 secondes hook battery back up fault should be gone or you have a bad oil sending unite cost 20.00
Aug 28, 2014 | Cub Cadet LTX1045 2009 and After Deck Belt...
How do I get rid of the 'Change Oil " Alarm after the oil change
Oil alert on the hour meter cannot be re set, it will stop itself after so many hours, crazy system!!
Mar 31, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet LT1045 oil light is flashing at 50 hours. Changed oil at 45 hours
I am thinking that might be a notice to change the oil, which is only for notification purposes. Check your owners manual. There may be a procedure to reset the timer when you change the oil.
Sep 04, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 1050 changed oil now its wants me to change oil again and it smokes really bad now to much oil or too little
the 1050 holds 57.5 oz slightly less than 2 qts 64 oz. the filler stick is marked. shiould be over the add mark not over the full mark
Jul 18, 2009 | Cub Cadet Street Sign- tractor lawn riding...
How do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
231 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
