Question about Whirlpool Duet GHW9150P Front Load Washer
What is the code H F mean on my washing machine
    President:
  • 1,382 Answers
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Posted on Aug 02, 2010
LG washing machine error codes I got TCL error code on LG my washing machine What does it mean?
that means you need to clean the tub. use your search engine on the net to learn how. then the error code should go off.
Jul 26, 2017 | LG Washing Machines
Tip
Hotpoint Washing Machine Error Codes or Fault Codes
If you are having a problem with your Hotpoint washing machine it is helpful to know what the error code means. Some of the problem are very simple to fix and do not require a service call to remedy the problem. Here is a list of error codes and the meanings for Hotpoint washing machines
If your error code has an E in front of the number and not an F as shown here, the meaning of the code is still the same
# F10 - This means there is no cold water coming into your washing machine You should check and make sure that the valves are on and that the hoses are not kinked.
# F11 - This means there is no hot water coming into the washer. Again make sure that the valves are on and that the hoses are not kinked anywhere. Also hot water will freeze before the cold water does, if it is very cold where you washer is, check for frozen pipes.
# F12 – This code means that the water is not filling when calling for mixed temperature water. Again, check the hoses and valves.
# F13 – If you have water supply problems this code could also display. Check all hoses and valves.
# F14 - A If this code comes up you have a problem with the washer water heating system. It is usually best to get a professional to repair this problem.
# F15 – The water is not being drained from the washing machine properly. Check the discharge hose to make sure that it is not blocked and that it rises to the minimum height requirement for your washer.
# F16 – The water level is or has been too high in the washing machine. The water inlet valve is probably not closing properly. Turn off the water at the hot and cold water valves and replace the water inlet valve.
# F17 - Door is not closing properly. Firmly push the door closed, and the washing machine should work. If you cannot get the machine to run by slamming the door, then you will need to have the door switch repaired or replace it your self.
# F20/1 – This means that you have a problem with the thermistor that senses the water temperature in your washing machine. It will need to be replaced. This error also could occur if the temperature where the washing machine is, is below freezing.
# F30/31 – This means that there is a problem with the washing machine motor. Check that you do not have too much in the washing machine. There also could be a communication problem to the motor. Unplug the washing machine to reset it and then try to run a cycle again.
# F40 - Water is below the minimum level for the heater to be working. You need to find out why there is not enough water entering the washing machine.
# F41 – There is a problem with the water level detection system.
# F50/51 – This means that the washing machine has lost its programming. The washer will run in a default mode till you can get it reprogrammed.
on Mar 16, 2010 | Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
What does the fault code e2 mean?
Kenmore e2 code Washing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > e2 code > Washing Machines
Kenmore washing machines e2 code related questions and answers. Ask yourKenmore questions. Get free help from washing machine experts.
Jul 26, 2015 | Washing Machines
E36 error code
My Bosch washing machine is showing error code E36 what's the meaning?
Feb 18, 2014 | Bosch Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
I have a stirling washing machine xqb90-701clps and the machine has come up with an E4 error code.. cannot find my manual. what does that code mean?
my machines not washing properly i think.. The wash is complete but theres still powder on the clothes.. What do i do to solve it?????
Jul 25, 2010 | Washing Machines
What does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
Oct 20, 2009 | Washing Machines
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
44 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
