Question about Fujitsu LifeBook E8010 Notebook
I have a fujitsu notebook model lbs6120-aa029e0b0. At first the notebook would start but not recognise the hard drive. when turning it on at other times it would work normally then freeze. Now the notebook will not turn on at all. (note the battery is no good so am using mains power. Any help to fix these problems would be appreciated. Regards Tad
    Problem Solver:
  • 10 Answers
If the notebook is not working at all now, you have to test the power supply to see if it is providing enough power to run the system. I would try to put the battery back on, let it charge for at least 12 hours, then try to turn on the system with the battery still installed on the machine. That way we can eliminate whether the power supply has sufficient voltage carrying capacity to operate the system.
If that doesnt work, then its time to call Fujitsu.
Posted on Aug 03, 2010
I have a fujitsu lifebook n6410 notebook that I forgot the hard drive password cant use computer without now help
These WEB sites may help remove the hard disk password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Apr 03, 2013 | Fujitsu LifeBook N6410 Notebook
Not use Touchpad Laptop cq40 to croll
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | Compaq Presario 700 470024-192 Notebook
I have a Fujitsu 80gb Sata hard Drive (2.5) which I have an adapter to use as a external Harddrive. However my computer and others only recognise it as a 14 gb drive. How do I get the full 80gb?
It seems this is caused by setting jumpers on your hard disk. Checkand return it to the correct position. Normally, your disk should be inthe position of Master or Slave.
Jan 16, 2011 | Fujitsu 50PK 80GB SATA 5400RPM 2.5 IN...
I want to upgrade my Fujitsu MHV2040AH 40 GB Hard Drive what is the biggest/fastes one i can replace with? i though i found another one but it doesnt have the right connectors. the fujitsu/toshiba site...
Your Fujitsu MHV2040AH is an IDE 2.5" 5400 rpm 40 GB hard drive.
Most Notebooks nowadays will use 2.5" SATA hard drive which is not compatible with IDE.
New IDE are getting harder to find and are therefore in general more expensive to buy than the equivalent SATA
You should be able to update the drive with most 2.5" HDD with either 5400rpm or 7200rpm (faster) with an IDE interface. Common 2.5 IDE capacity would be 120Gb and 250Gb (320GB and 500GB are also available but could be a bit expensive). The important factors are physical size to fit in your notebook/casing and IDE interface. The BIOS support for larger drive can also be a factor but as a rule, worst case situation, a larger capacity drive can always be used at a lower capacity
Hope it helps.
Dec 15, 2010 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
Computer recognises drive but does not show drive letter
Click Start
Right-mouse click on My Computer
Choose Manage
Click to get to Disk Management (local)
Use Disk Management to "create" and "format' a partition onto the disk-drive, and to assign a drive-letter.
May 07, 2010 | Fujitsu Siemens (MAN3184MCB) Hard Drive
I have a Fujitsu Lifebook LBS6120 notebook
Turn on as you did before and leave on for 10 minutes. Then, try turning OFF the computer by keeoing the POWER button pressed for 7 secons. If the computer goes off, then your screen is fried and the computer is actually booting up normally... you just can't see it ;)
Mar 17, 2010 | Fujitsu LifeBook E8010 Notebook
I have lost my recovery cd for Siemens AMILO Pr, how can i instal windows XP SP2 again on my system as it says there is no hard disk connected. Plz help me
If You're Getting That Message... Then It's Not Recognising The Physical Hardware... The Drive Itself...
Pull Hard Drive Out And Reinsert It... Then Go Into Your BIOS Setup... Ensure That Your Hard Drive Shows Up In There....If Not, Your Hard Drive Most Likely Is Faulty and Will Need Replacing..
You Will Still Need Either A Recovery CD Or Just An OS Cd..(XP/Vista etc..)
Dec 03, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
I want the bios recognise usb flash
Start Windows.
Insert the USB flash-memory device.
Windows should recognize the device, and assign a "drive-letter", such as 'E:' or 'F:'.
Open "My Computer".
Select the 'E:' or 'F:' drive, and browse the files/folders.
Nov 14, 2009 | Fujitsu AMILO D-7820 Notebook
My computer will not restart
It sounds like a hard drive crash but hopefully just one of the core files. If you get to another computer with a CD burner, download a copy of the "Ultimate Boot Disk" (find on Google - it's free) and start the laptop with that disk - you can then use the drive utilities to test the hard drive.
Oct 21, 2007 | Fujitsu AMILO M-6500 Notebook
Fujitsu LifeBook E8010 Notebook Logo
230 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
