Dynex 26" TV Close caption is greyed out on menu. CCD button does not work
5 Suggested Answers
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Posted on Mar 10, 2008
  • 3 Answers
SOURCE: 26 LCD TV brand name from Best Buy - Insigna
I' can't imagine the Geek Squad couldn't tell you over the phone how to resolve the issue. If they can't call the local distribution center in your area and ask for the man in charge.
In the interst of customer service they should take care of you. What model number do you have? I may have some info on the cure.
OTBMAN
Posted on Apr 08, 2008
SOURCE: LG LCD TV Model 42LB5D. The closed caption option is greyed out. Help please.
redrover 11-13-2007, 01:03 PM Well I stumbled onto the solution to my problem, finally, but no thanks to any of the tech at my cable
Posted on Feb 21, 2009
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
How do i delete closed captioning?
The button marked CCD "close caption display"
BTY if the TV programing is coming via cable box that the CCD feature needs to be turned off in the cable box under settings. If there is a cable remote the CC will usually be near to the "cable" button
26052381-dbyvlhzmxmckmsztft4cqgrd-4-0.jpg I hope that this helps?
Jan 13, 2016 | Dynex DX-L19-10A LCD TV
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
I have a DYNEX 42"
Do you have a cable or satellite box connected to the TV? If so the box is probably what is providing the Closed Caption and not the TV.
Robert
Feb 26, 2011 | Dynex DX-LCD37 TV
My closed caption on my new dynex 26L 150A11 will not turn on. I have followed all instructions in the book. I need the cc. any one have an answer? thanks cosycat
There are several possibilities here so you will need to work with me to resolve this problem. In order for Closed Captioning (CC) to work, you need to make sure the CC settings are correct on the TV, and then make sure they CC is switched on. In addition, if you are using a cable or satellite receiver box, CC also needs to be switched on for these "boxes".
It's easiest to start with the TV. Please make sure you have done the following:
1. Check the Closed Caption settings are as follows from the TV on-screen menu as follows:
a) Press the "MENU" button on the DYNEX remote
b) Press the RIGHT arrow twice to highlight the "SETUP" menu
c) Press the DOWN arrow once to open the "SETUP" menu
d) Press the DOWN arrow twice to highlight "CLOSED CAPTION"
e) Press the RIGHT arrow or the "ENTER" button once to open the CLOSED CAPTION MENU
f) Make sure the Closed Caption option "CC MODE" is set to "ON". This can be changed using the UP/DOWN arrow keys to highlight "CC MODE" and using the LEFT/RIGHT arrows to switch between off and on.
The "Basic Selection" and "Advanced Selection" settings are for analogue and digital closed-captions respectively. In addition, the "Options" sub-menu can be used to change the size and style of the digital closed captions (Advanced Selection). All three of these options should eventually be set according to your personal preferences, but for the purposes of making sure it is working, I suggest you set them as follows:
Basic Selection = CC1
Advanced Selection = Service 1
These options are the basic settings which will display only the spoken dialogue of the TV program.
g) Press "EXIT" on the remote to close the menu and return to viewing mode.
2. Press the "CCD" button on your Dynex remote control. This can be found in the bottom right-hand corner of the remote. Each press of the "CCD" button will cycle the closed captions between ON and OFF. (CCD means Closed Caption Display)
3. Check the Closed Captions are displayed and then adjust the Basic and Advanced Selection options until the type and appearance of the closed captions are how you like them.
If you have done the above and still cannot get it to work, please let me know whether you are using a cable or satellite receiver and the brand/model number. I will then be able to assist you further.
Regards,
BElectric
Dec 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Why does close-caption appear on screen eac time I turn it on.
On your remote control find the CCD button and press it until you find the option to turn off the closed caption or select the closed caption option to use only when the sound is muted. If this does not eliminate the problem, you may have a switching problem in the control panel.Try turning off your television for a period of time and then turn it on and try resetting the control. If this fails you may want to contact customer service for technical help at 1-877-467-4289. Hope this helps you with your problem.
Apr 24, 2009 | Insignia LCDTV26 26 in. Television
Closed captions will not work thru my tv remote
I hope this was resolved but this is a dish page and I am unable to answer Comcast issues.
Feb 14, 2009 | DISH Network 811 HD DTV Receiver
Close caption writin words display all the time on tv how do i
Go to menu aand look for tv settings. go to closed caption and continue to scroll untill you see off
Nov 26, 2008 | Mintek DTV-263 26 in. LCD Television
Closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
Nov 27, 2007 | LG 42PX5D 42 in. Plasma HDTV
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
359 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
