Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Refrigerator set on 5 the coldest and there is a water dripping
Whirlpool refrigerator. Freezer works fine ,no problem But refrigerator has water dripping where air suppose to come in from freezer portion.Please let me know , what I can do to fix it?
Thanks Albert
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
We have a Whirlpool with the freezer on top. The freezer is around 5 degrees, but the refrig. won't go below 47 even at the coldest setting. We vacuumed all of the vents and tubes in the lower front
The fan in the freezer may have stopped working. Or it could be the defrost drain tube is stopped up. Remove the rear plate in the freezer to expose the fan motor. With the rear cover off You can see if the freezer box has frozen over the drain. If so unplug refrigerator use a hair dryer to melt the ice. Keep heating the drain area until water runs down through the drain. Fan motors are available by model number on line or at local appliance stores.
Dec 30, 2013 | Whirlpool Refrigerators
Hi, I turned the refrigerator off to clean it out, turned it back on but not getting cold the freezer is working fine. Its a whirlpool about 3-5 years old. model # er2chmxpoo4.thanks hope you can help....
Do you hear a fan running in the freezer? If not, then you'll need to replace the evaporator fan motor, located in the freezer compartment behind the evaporator cover. Part # W10189703 . Now the fan would only run if the compressor was running, so turn the dials all the way to the coldest setting and check again to see if the fan is running. Hope this helps.
Mar 23, 2011 | Whirlpool Refrigerators
Refrigerator will only get 58 degrees no colder, freezer is working fine, dial on fridge is on coldest setting...help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Nov 28, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Water dripping from top rear center of refer section. icing up and dripping, about a cup a day. seems unrelated to icemaker operations or humidity. What direction do numbers mean when setting temp for...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 26, 2010 | KitchenAid Refrigerators
I have Whirlpool ET8MHK Top Freezer Refrigerator and all of a sudden it stopped cooling. I had to crack up the setting to coldest to work. what part needs to be placed?
heatman101
Aug 29, 2010 | Whirlpool ET8MTKX Top Freezer Refrigerator
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker was hot and could hear water dripping on
yes.you will have to replace the ice maker.if further used without replaceing the compressor will get damaged and you will completely loose cooling in your unit.
Mar 07, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Whirlpool Gold GS6NBEXRB01 - While Auto-Defrosting, the water drips into freezer from inside Grill
you have a frozen or blocked defrost drain behind the back panel with the vents in it remove the panel and clear the drain at the bottom in the silver pan
Jun 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
137 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
