My maytag dryer will turn and run, but there is no heat and the timer never moves from where you set it to start out at. Is it the heating element that has gone bad, or can a timer go out and cause the dryer to act this way?
Hi, If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly. if
you dryer is gas check out this gas
no heat
tip.... If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip... heatman101
