Question about iRiver H10 MP3 Player
Installation cd missing for iriver h10
I have lost my installation cd what are my options
cheers allan
Iriver h10 when switch on it shows system file missing connect h
I'm not sure my solution can help you or not.
I've got this message too but after I formated H10 by Windows.
First backup all files by window explorer.
Open iriver plus and go to > Option > Portable Device Initialization.
This function will delete all data, Please sure that you already backup all of your data from H10.
After initialize process finished, it will ask you to disconnect and connect it agian.
------ Steps below, I can't explain it clearly. May be you will not have the same results as me. I hope it can rise you some ideas how it comes.
I followed that instruction but after I disconnected it again and turned on, expected that msg will disappear, IT's NOT! a bit freak out.
Ok claim down,
I tried to turn it off but I can't then I pushed its battery out and put it back and turned on, that msg showed up again.
Then I connected H10 to Iriver plus again and it upgrades firmware automatically.
At the end after I disconnected and turn on my H10 it works perfectly.
I'm not a native English so my language could make you confused, any questions you can contact me. :)
Jul 16, 2009 | iRiver H10 MP3 Player
System files missing
I got this from another post:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Also go here for the firmware directly: http://iriverinc.com/support/hd/h10_5-6gb.aspx
Apr 13, 2009 | iRiver H10 MP3 Player
I fixed this problem for my mate, here's what I did:
hope this helps.
Here is for the Iriver H10 software:
IRiver H10 - System files missing
please, my new iriver h10 is not open. it will say "System files missing"
Aug 03, 2008 | iRiver H10 MP3 Player
H10 20 GB RECOVERY TOOL
Hey malvene,
If you've lost your software installation disc, you should be able to obtain all the necessary firmware updates and recovery tools by visiting the manufacturer's website:
http://www.iriver.com/product/p_detail.asp?pidx=61
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 03, 2008 | iRiver H10 MP3 Player
Lost h10 iriver installation disk
You can download the software from this site;
http://www.iriver.com.au/iriver/index.cfm?pageID=10001
Probably also from worldwide site. www.iriver.com
As a work-around you can copy files with Explorer to the Music folder and use the Browser on H10 to play them.
Feb 14, 2008 | iRiver H10 MP3 Player
Iriver h10
During instaling new Firmware there is option for FORMAT disk, thus all data will be deleted and disk reformated
and then also can try to chech errors on disk by standart windows properties
Jan 29, 2008 | iRiver H10 MP3 Player
Iriver H10 saying system Files missing
Try doing a format via windows explorer. Right click on the drive and then format as fat32. Then unplug and open iriver plus. Reconnect. See if that works. Good luck!
Jun 29, 2007 | iRiver H10 MP3 Player
Reacquire firmware from iRiver website
Nov 13, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
157 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
