Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture Sony Trinitron, large screen and an older model. There is a red light that blinks under the words "sleep mode" -- Anyone have a suggestion? Did I blow the TV tube?
  • 49 Answers
Your sony ctv is in sleepmode. so kindly press sleep button at remote control .other wise you swith off tv ( that means remove the mains wire from pluck point) then after 5 minutes switch on it will OK.
Posted on Aug 02, 2010
Sony Trinitron Model KV20FV10- when I turn it on the Sound comes on BUT no picture and the red light for the Standby Times keeps flashing non-stop.
How many times do this standby light blinks. It is fault indications. You can get an idea about the faulty section inside the TV, by counting these blinks occurs at one time switch ON. These are called blinking codes. For more details about blinking codes to Sony brand TVs, check this link. Pull up older posts there. Surf the site with patience.
Mar 21, 2013 | Televison & Video
Hi I have a sony KV-ES34M31 -- I pressed the sleep button by mistake it won/t come out of that mode. 2 blinks in a 3 sec period.
The main power supply regulator board has damaged. The fault you see as two blinks are its indication.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Pull up older posts there. Cause for two blinks of standby light with Sony sets are described in detail. Check it.
May 19, 2012 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I have a sony trinitron kd-32fs170....all i get is 4 red blinks no picture
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
No frame in other words.
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony triniton,no sound or picture,flashing red light blinking!
the main problem of your tv set is the main power or what u call the regulator.the red light blinking it means your tv set is on standby mode.
Feb 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Red standby light light blinking
The 5 blinks can indicate a picture tube starting to fail. Carefully open up the back and look for the flyback transformer. It will be the part with the large red wire coming out the top that goes to the side of the picture tube. There should be 2 controls on the flyback, screen and focus. Turn the screen control slightly clockwise. If the set stays on, the picture tube is starting to fail and you have bought yourself time to find a replacement. If that fails, then you will need to investigate other possibilities that will involve soldering. Let me know if you need to do that.
The 6 blinks indicate no horiszontal. This can be as simple as a couple of bad capacitors or the "jungle" IC. If you can solder, please post another question with the model and a brief description indicating that you can work in the set and we'll continue to track this down.
Thanks,
Dan
Dec 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
Feb 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony kv35s66: No picture, just sound and red blinking
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
249 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
