Question about Hobart D300 Stand Mixer
What kind of oil i can used for hobart d300 - Hobart D300 Stand Mixer
    Scholar:
  • 44 Answers
Transmission uses #0 weight grease, best to get direct from Hobart (their grease is the correct weight and approved by U.S. FDA & USDA as safe for use in food equipment) but if you insist on not doing so, at least obtain an Extreme Pressure #0 grease and don't overpack the transmission, I believe it should have 35 oz. if memory serves right.
Uses a heavier grease for the planetary gear, use #2 weight. Don't need much, just a light coat on the planetary gear.
Bowl lift rails use medium weight oil, again use food grade oil supplied by Hobart.
Posted on Aug 04, 2010
bigg t
  • 640 Answers
SOURCE: how do i lubricate my 20 qt Hobart mixer and what kind of oil do i use?
you can call your local hobart branch for the part number,but you use lithium grease in the unit.in order to change the grease the transmission needs to be opened and so does the planetary. i service these mixers alot i work for hobart.if you need any more help/questions let me know.
Posted on Dec 25, 2007
Cuisinexpert
  • 61 Answers
SOURCE: oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278)
Good luck! :)
Posted on Aug 27, 2009
  • 41 Answers
SOURCE: transmission oil
this unit uses grease if it is leaking out the grease has broken and needs replacing
Posted on Dec 09, 2008
housejess
  • 317 Answers
SOURCE: what kind of oil do i use and how much for HOBART
4 in 1 oil
Posted on Nov 16, 2009
  • 110 Answers
SOURCE: hello i would like to know what kind of oil to use
d-300 and d-340 mixers dont use oil they use grease -47 can be bought @any hobart office. there are several reasons why this problem can happen. try tighning the planetary nut all the way then back off 1/4 TURN .also do the same with the top main shaft nut if that doesnt work contact me back
Posted on Jan 09, 2010
My d300 hobart mixer is dripping oil when I am using it. How can I stop the oil from dripping out
It uses grease which breaks down over time. The transmission has to opened up and all of the old lube removed and replaced with fresh lube and the bottom seal replaced. Contact your local Hobart office. www.hobartservice.com to locate your local office.
Nov 04, 2010 | Hobart D300-6036 Mixer
How to remove bearings from a Hobart D300T
I have a D300 mixer and the 2nd gear kind of misses or just vibrates a little what is this?
Jan 01, 2010 | Hobart D300 Stand Mixer
I HAVE A HOBART MIXER D300 ML#11627 I NEED TO KNOW WHAT KIND OF GREASE TO USE FOR TRANSMISSION,AND WHERE CAN I GET IT
Goto hobartcorp.com,create a username and then you will be able to find out what your looking for.I know that these mixers used oil when they where new but now changed to grease.Any ? let me know as im a hobart tech a repair these often.
Nov 19, 2009 | Hobart D300 Stand Mixer
Have an old hobart 140 mixer and i want to chang oil what kind of oil do i use
you need to replace it with a "FOOD-GRADE" mineral oil or FOOD-GRADE white lithium grease, you can get this from "Lubri-Plate" at their web-site
Nov 18, 2009 | Hobart D300 Stand Mixer
Hello i would like to know what kind of oil to use on a Hobart mixer d300 its a 3 speed mixer the problem im having is 3rd speed runs like 1st speed could it be the clutch that is bad thank you
Nov 16, 2009 | Food Mixers
From what part of the mixer do we change the oil? And what kind of oil does it use?
Use food grade grease and you may have to split the motor housing.The grease is for the gearing in the head. At an Appliance parts store That's where to get some. :-)
Oct 26, 2009 | Hobart D300 Stand Mixer
Oil leaking from hobart d300 mixer
Good luck! :)
Aug 27, 2009 | Hobart D300 Stand Mixer
My Hobart D300 mixer appears to be leaking oil/grease
Hi,I'm a hobart tech and repair these mixer's often.If you see oil in the drip cup then the center shaft seal in the transmission is worn.If there is oil near the transformer then the motor shaft seal is also bad.Hobart doesnt release their service manuals to the public but if you go to their site www.hobartcorp.com you can register for free and get a parts manual thats helpful.If you need help with the repair let me know,i can step you through it.
Mar 17, 2009 | Hobart D300 Stand Mixer
Transmission oil
Sep 09, 2008 | Hobart D300 Stand Mixer
Hobart D300 Stand Mixer Logo
893 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
