Question about GE JTP85 Electric Double Oven
My GE JTP85 microwave turntable does not turn. It makes a loud clicking sound like a stripped gear. It will turn sometimes about 1/4 or 1/2 turn then start clicking again. Can I get replacement parts and install them? I'm pretty mechanical with washer, dryer replacement parts. Sounds like there is no replacement microwave oven. Thanks a million. GQ
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: F3 Error Code - GE Electric Oven JTP18
all ge codes f3 are saying ot replace thermal sensor, you can check the harness connecting them for a pinched or burnt wire i guess, as far as getting a part number , you can enter complete modle number her e and look for the sensor, i checked just the partial number you gave and a few different ones showed up
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 23, 2008
ginko
  • 19396 Answers
SOURCE: Microwave will turn on but not heat
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
heatman101
  • 43501 Answers
SOURCE: Convection works but Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
duid
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: the turntable on my JTP85
heatman101
Posted on Nov 24, 2010
Scb2000 GE Advantium 240 microwave not heating
It s the magnetron tube, thats what makes the microwaves. Not a hard fix, you can order one from sundberg.com or marcone .com with your model number
Jul 19, 2012 | GE Monogram 30" 240 Volt Black Built In...
GE Profile JTP85 (installed 1998). The lower heat element in the lower oven will not heat. I can make the upper element heat up by using the BROIL function, but neither element gets warm on BAKE.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 11, 2010 | GE JTP85 Electric Double Oven
The turn table will not turn and the light will not light when I operate the Microwave. It heats fine....
heatman101
Sep 30, 2010 | GE JTP85 Electric Double Oven
MICROWAVE IS NOT HEATING AND MAKES NOISE
heatman101
Mar 13, 2010 | GE JTP85 Electric Double Oven
GE MODEL#JTP85W0W MICROWAVE IS NOT HEATING AND MAKING NOISE
heatman101
Microwave is not heating and making loud noise and smells like burning
heatman101
jkl
Jan 20, 2010 | GE JTP85 Electric Double Oven
Nov 26, 2007 | GE JTP85 Electric Double Oven
MIcrowave stopped working
there is a 15 or 20 amp fuse behind the control panel. turn power off at breaker, remove control pand the fuse will either be round and the size of a quarter, screwed in or will be about an inch long and cliped into place
Nov 19, 2007 | GE JTP85 Electric Double Oven
Turntable not turning
I fixed the problem with my microwave turntable motor without having to replace it. I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate. Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ?bumps? on the underside of the gear on top and washer on the bottom. Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place. If this worked for you please let me know ? karlet@bellsouth.net
Sep 11, 2007 | GE JTP85 Electric Double Oven
GE JTP85 Electric Double Oven Logo
67 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
