Question about Miele T9820 Gas Dryer
The dryer doesn´t work
Miele T9820 check filter vent appears
  • 4 Answers
I had the same problem with my dryer. The Miele technician came and took a look at it. There was nothing wrong with any parts. My vent pipe was kind of crumbling, so he replaced that. He then scrubbed and washed the lint filter with dishwasher soap and
the green scrubber, He also did a PC update of the firmware. My
unit already had the latest version, but he did erase all the error codes.
After all these rather simple steps the dryer started working like a charm.
He said the most probable caused was gummed lint filter because of using the dryer sheets. Miele dryers are designed to prevent static cling and he advised not use these sheets as they contain wax-like substance.
I would suggest scrub cleaning the lint filter first and see if that helps.
Posted on Aug 27, 2010
Miele t9820 service manual
did you get your software update done during the campaign? Call miele for the software update. while the tech is there, ask him any question you want. it is free of charge, and it is a safety issue on that dryer. 800 999 1360. dsc software update.
May 02, 2012 | Miele T9820 Gas Dryer
Check filter/vent lights are on. we have cleaned everything and dryer stii wont work
there is a sensor below the lint screen, it has two screws, and this may have a film on it from the dryer sheets. The easiest and safest way to clean is take it apart(the dryer) gently/lightly wipe the sensor off. Be careful not to damage it, Good Luck Tim
Jan 16, 2011 | Miele T9820 Gas Dryer
Miele gas dryer drum won't turn, but turns on like it works
check out my tips on dryers
the tensioner and belt needs to be replaced more than likely
May 09, 2010 | Miele T9820 Gas Dryer
Got a software update and now dryer is flashing all indicators
try turn power off to dry,if still not working call the tech back that did the software update
Apr 24, 2010 | Miele T9820 Gas Dryer
Clean filter / vent indicator stops unit after T9820 MIELE GAS DR
Call Miele and schedule a PC update. When the technician comes he will do the update, if needed, and will reset the error codes.
Apr 04, 2010 | Miele T9820 Gas Dryer
How do i replace the dryer belt on my t9820 miele gas dryer
Don't mess with it. Call Miele. The front seal is probably worn and caused the belt to break.
Feb 04, 2010 | Miele T9820 Gas Dryer
Pop the top miele t9820 dryer gas
Open the door, at the top of the recessed door opening you will see two round plastic caps. Remove these and you will see screw behind that you have to remove. Some models the caps are on the right and left hand sides. Slide the top towards the back after removing screws and the top will lift off. Good Luck, Appliance Specialists
Jan 06, 2010 | Miele T9820 Gas Dryer
Dryer drum won't turn but dryer will turn on like its working. no fault notice or any indicator something is wrong.
Check the drive belt. Pop the top (spring loaded) to check. If broken, remove the front panel for full access.
Thanks for your quesiton
Jan 05, 2010 | Miele T9820 Gas Dryer
Miele T9820 runs except no heat
you have probably blown your thermostat especially if your condenser is blocked and hasn't been cleaned. this causes the unit to over heat and to protect the heater element the thermostat blows and breaks the electrical circuit. you will need a Miele service tech or service agent to repair the unit.
Sep 29, 2009 | Miele T9820 Gas Dryer
Check vent/lint indicator alert
Contact Miele 1800-999-1360 for a new blower fan
Jun 07, 2009 | Miele T9820 Gas Dryer
Miele T9820 Gas Dryer Logo
351 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
