RCA F36150
RCA TV Model: F36150 (ATC113CA1 Chassis)
No picture and sound, only a high pitch sound when plugged in.
    Problem Solver:
  • 16 Answers
The problem of your TV was the Flayback transformer or on the power supply IC. replace it..
Posted on Apr 25, 2008
Tv will not power on. Hear a high pitched sound
the horizonal output transistor is shorted-replace it also resolder coil near transistor-if output shorts again flyback transformer is bad
Sep 15, 2009 | RCA F36673ET 36" TV
When my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
May 01, 2009 | RCA 36F530T 36" TV
RCA F32650 Bad Circuit Board
try pts electronics, just go to search engine and type board number and it will tell where yoiu can buy it . at least 250.00
though.
bc
Feb 26, 2009 | RCA F32650 32" TV
High pitch noise and the power light flashes.
most likely it is the flyback transformer. I have had meny RCA tv's with a bad Flyback and H.O.T transistor bad. Cost depends on the service center. Parts average around $60.00 dealer, so depending on mark up and shop labor it could vary greatly. If you have never changed these parts it is best to have a service man do it ... Take it to the shop and save the trip call charge $49.00 and up to $125.00..
Nov 18, 2008 | RCA F36650 36" TV
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
Loud sound, No TV Picture
Power supply needs to be replaced - common problem with these tv"s
Sep 18, 2008 | RCA 32F531T 32" TV
RCA F366550
your hori out put is proably shorted,which means you have no high voltage, also your flyback transformer could bad.
Jan 18, 2008 | RCA F36650 36" TV
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
High Pitch Sounds
In this model the horizontal drive coil vibrates and makes a high pitch squeal. Most times it is intermitent. Touching on the coil with something (non electrical, like wood) will make it stop or change it's pitch. The fix my shop uses: It's not to technical, but, we put fingernail polish around the coil. It's a remedy I've used for decades and has always worked. Some shops use a hot glue gun. With the back open you can hear the coil to locate it. When fixing the problem have the set unplugged. When a technician is working on a television while it's plugged in. He uses only one hand and stays away from the high voltage.
Jun 25, 2007 | RCA HD52W59 HDTV Projection Television
Sound is fine, but no picture
could be a bad solder connection or maybe the CRT socket has come off slightly. I lean more to a bad solder connection at the flyback area screen G2
Dec 14, 2006 | RCA F36650 36" TV
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
