Question about Dryers
Rattle noise when is on. Sound more like grinding on some thing.
  • Dryers Master
  • 8,220 Answers
Open up the dryer and inspect the glides,rollers, and idler. Use this guide
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 02, 2010
What is causing rattling grinding noise at idle especially in my 89 4.5 DeVille?
The technique I always used to identify where such a noise was coming from was to use a very long screwdriver (2 feet long), while the engine is running. CAREFULLY touch the screwdriver end to each pulley or other object under the hood, and put your ear to the handle. The device making the noise will become very clear.
It could be AC pump/clutch, alternator, water pump, power steering pump, etc.
May 20, 2015 | Cadillac DeVille Cars & Trucks
How we can solved the hp lj p2055dn printer noise
Hopefully one of the first four suggestions helped you. If not if you could post more detail as to what kind of noise is the machine making: a grinding noise, a squealing noise, how loud is it. descriptions such as that would be helpful in diagnosing the issue. Without a description of the noise any of those first four posts could be relevant. The easiest thing to try first would of course be a toner cartridge I have experienced them many times making noises especially if they're aftermarket cartridges. Other than that grinding noises are typically fuser related in that machine, with squealing and high pitch noises the description of the noise is very important because it could be a fuse or it could just be dirt in a gear cluster rubbing on a shaft or it could be the laser assembly. Ireally hate to post absolute diagnosis without enough detail especially when it comes to you having to spend more money. Hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
Sep 24, 2014 | HP P2035N LaserJet Monochrome Printer
93 s10 rattle/rotational grinding noise while stopped or accelerating close to the sound of a bearing that is bad. The rattle can be felt if you grap the steering column. Replaced power steering pump
Automatic or manual trans? Manual trans could be throwout bearing. Other moving parts at idle that have bearings - alternator, a/c compressor, water pump. Auto parts store or harbor freight sells stethoscope to listen to stuff like that. Use it to determine where sound comes from. Careful when using near moving parts.
Jan 16, 2014 | Cars & Trucks
Grinding sound
what car
what year.
no mater, find any ASE mechanic. (is USA< and no car stated)
noise is most times serious, for you and engine.
Sep 28, 2013 | Honda Cars & Trucks
Rattling noise when accelerating
I would need to know what vehicle this is? 4 Cylinder. V6? 3.0? There are a few things it could be,
If the Engine is Moving, it could be hitting something so I would check the Motor Mounts (Happens quite Frequently on Taurus)
Check the Tension of your Serpentine Belt
Apr 05, 2013 | Ford Fusion Cars & Trucks
Grinding/Low Whining noise when turning
sounds like the power sterring pump check valve is failing because it only when you turn, try to turn the wheels standing still to verify the noise, if noise present, replace the ps pump.
Jul 09, 2009 | 2004 Chevrolet Silverado
Harsh grinding noise while in gear and car won't drive!
Had the exact same thing in my 93 and it was the CV Axles - they have a C clip that hold them in place - sometimes the C clip and fail; sometimes you simply have to replace the CV Axles - much cheaper then a tranny; a good suspension shop should be able to diagnos w/o it costing you an arm and a leg.
Jun 15, 2009 | 1993 Geo Prizm
Dryers Logo
Top Dryers Experts
Marvin
Marvin
