Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
My Robo-Kleen does not seem to clean up anything form the pool floor. this is the first time is used it and was wondering if i missed anything. it moves around, but at the end of the cycle the filter bag was perfectly clean. there is a small button/ knob on the robot by the one wheel, there is no mention in the manual about this, do i need to do anything here?
  • 201 Answers
I had this problem
if you noticed the pump shoots water to the top surface when moving, but after time , the fan will freeze up due to the water rusting it , youll see the car move but it wont pump water anymore, you can see the fan freeze on top,ill have to take mine apart and try to lube it somehow, not sure what kind though,graphite maybe
Posted on Sep 06, 2011
  • 640 Answers
Here is a copy of the users manual for these pool cleaners. I would go over the installation instructions again. You most likely do not have something connected properly. The button that you are talking about should be the one that controls wheel movement, but that will not have anything to do with suction. Check all of your connections (specifically) to make sure that you don't have a leak somewhere.
Posted on May 26, 2011
My robo kleen pool cleaned keeps flipping upside down. happens every time, i will watch it for a few minutes then come back later to check on it and it is upside down in the pool
check to see if the fan on top moves
if its stuck , then the motor is not pumping constant
and the pump may need some kind of lube
graphite perhaps
Sep 03, 2011 | Smartpool Dolphin Robo - Kleen Above...
Robo - Kleen Above Ground Robotic Pool Cleaner seems to be leaking oil? Also, fan does not seem to be running all the time?
Motor is in oil bath. When it leaks that means water is getting into motor housing. Try and take apart to clean and dryout. Then needs to be sealed and filled with oil. This worked with mine not sure what type oil. Looks like mineral oil or something similar.
Jul 02, 2011 | Smartpool Dolphin Robo - Kleen Above...
I have a Robo Kleen robotic pool cleaner, it still moves around but is no longer picking anything up. The bag is clean. Can I purchase a pump for it?
You should be able to purchase pumps for these automatic pool cleaners from a pool supply company, but I would take it to a professional first. It could be something that is easily fixed without purchasing an expensive part.
Aug 24, 2010 | Smartpool Dolphin Robo - Kleen Above...
What is the output amps on robo kleen transformer
Here is the users manual for these pool cleaners. You might be able to locate the information you are looking for there in the parts specification manual.
http://www.backyardcitypools.com/Pool-Cleaners-Automatic.htm
Jul 03, 2010 | Smartpool Dolphin Robo - Kleen Above...
Robo Kleen pool cleaner troublshootong
One thing that you might want to try on these pool cleaners is removing the limit screw on the axle for greater angle of tandem wheels. Make sure your filter bag is not clogged or partially clogged because this cause restrict movement. Check for debris jammed in your drive system (wheels, axles, etc.)
Aug 16, 2009 | Smartpool Pool Hog Ig Robotic Automatic In...
I have a robo-kleen pool cleaner which stops
If debris is entering the bag, it may be as simple as that. The bag is clogged. We typically recommend hand cleaning a pool before using an auto cleaner specifically for that problem. You might have to remove and clean the bag 50-75 times. Much easier to hand vac first. If no debris is getting into the bag before it stops, it could be a problem with the motor. we have seen them "short cycle" and require replacement. Rob
Jul 14, 2009 | Pool & Spa
Wondering if a robo-kleen robotic pool cleaner can be used in an inground pool?
You will find it won't climb walls, but should clean just fine on the bottom area.
S. Christian dansker01@msn.com
Jun 05, 2009 | Smartpool Dolphin Robo - Kleen Above...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
112 people viewed this question
Top Smartpool Pool & Spa Experts
Marvin
Marvin
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
