Question about Sony Playstation 3 (PS3) Console
Playstation 3 will turn on but no video will show on the tv
    President:
  • 1,139 Answers
Try resetting the video back to standard definition by holding the power button down for 5 seconds.
Hope this helps
Posted on Aug 02, 2010
My ps3 screen wont show when i turn the ps3 on.
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 28, 2010 | Sony PlayStation 3 40GB System
Everything is hooked up and the ps3 turns on but it doesn't show up on the T.V
Jun 27, 2010 | Sony Playstation 3 (PS3) Console
Nothing shows up on the TV
Hi, troubleshoot all the connecting cables, you will find one faulty to replace and enjoy your game.
Take care.
May 10, 2010 | Sony Playstation 3 (PS3) Console
Why wont my playstation 3 show up on the tv?
open the top up and make sure it has the right wires going into the video slot
May 09, 2010 | Sony Playstation 3 (PS3) Console
No video no audio
well make sure all the cables that are coloured... red, yellow, and white are in the right holes... also make sure that the t.v. is on the right place... click T.V./Video until it gets to the right channel. Hope it helps
Jul 25, 2009 | Sony Playstation 3 (PS3) Console
No signal
make sure the cable are set right if they are it could be your cables if your purchase the cables from bestbuy you can take them back open if that doesnt help then you need to send it back
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
No signal
turn off ,then turn on and try having the power button pressed for 5 secs to reset the video output...
Playstation turns on but TV says "no signal"
You could try the screen reset..... When the consoles in standby mode... press and hold the power button for over 5 seconds till you hear a diferent kind of beep and then it runs the optimal screen settings mode.. i hope this helps
Jun 12, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
when you turn the ps3 on hold down the power buttion on the console until it beeps and the lights flash.
May 19, 2008 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
