Question about RCA D52W19 52" Rear Projection Television
Rca flat screen 42inch about two years old hdmi ports do not work how to fix?
  • RCA Master
  • 8,617 Answers
Replace the small signal Board ( Board with inputs) you can get a replacement small signal board from www.tvrepairworld.com
Posted on Aug 03, 2010
How to repair HTMI port "no signal" on screen
Just pull out the socket to the port, and fix an other in that place. It will come out easily as you pull out, and can be fixed a new one for just one hard push.
Sep 26, 2016 | RCA Televison & Video
How to get HDMI to show up on the TV with the remote
Hi George,
For this your TV has to have the HDMI input port. If it has one, please press the input key on the remote control. You will see the input source menu on the screen. Select HDMI input.
Dec 06, 2015 | Televison & Video
HDMI (and VGA) ports not working with my laptop
not sure which part is not working as expected but could it be the tv does not support the resolution from the computer? Try change it to a lower resolution/framerate and see if that does produce an image.
Jan 26, 2014 | RCA 42" Class - LCD - 1080p - 60Hz - HDTV
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
I have a polaroid lcd tv 32 inch. i turned it on today and there was no picture but all the sound was there even with a dvd playing there is no picture only sound i have checked all leads and everything...
Well it very well could be the three color tubes, or power board the problem. BUT before you try that check your HDMI cable. HDMI cables have to be 100% in to fully work sometimes if out just a bit they will produce this issue where you have no picture but sound.
Or try a new HDMI cable, if you don't have HDMI and it's doing it on multiple ports including RCA, RF, HD Component then it's a problem with the tv itself and you'll need to call a repairman.
Mar 02, 2011 | Polaroid 3211TLXB 32 in. LCD Television
Hdmi ports are not working
That HD mode.That good what else do u want.Unplug,replug the tv an hour later,might get HDMI ports work again.Not,ur Tuner board is dead.
Apr 26, 2010 | JVC LT-42X688 42 in. LCD HDTV
Itstarted flashing on the whites and light colors?
Ur main video backlight board it dying,must replaced before it kill ur power supply board.
Nov 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Jul 03, 2009 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
228 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
