Question about Vizio GV42L 42 in. LCD Television
Line running UP through tv
There are two lines rolling up the tv. This is on every channel and this just happened over the weekend. Any ideas what has caused this and how I can fix it? Thanks.
  • 11,361 Answers
Inspect the power supply module for bad DC filter caps, sometime it may look OK without having any bulging/leaking top which you will need the cap meter with ESR function testing to verify.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Aug 02, 2010
My Panasonic smart tv had a thin blue line running down the middle of the screen earlier today. When a tv show was playing the right side of the blue line was fuzzy. Tonight I came home and now when I turn...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Mar 28, 2015 | Panasonic Televison & Video
New JVC TV Dropping programmed channels
It sounds that the main system control memory IC to this TV is faulty. Contact any service technician to confirm. This is not a user repairable fault. Gopakumar Gopalan Google
Mar 09, 2014 | JVC Televison & Video
TV is showing no signal. So I did a channel search and it stops and says unable to continue channel search due to error. I even unplugged - left for an hour and still does the same thing. I then hooked...
this could be a fault with the tv actual connector for the cable check the connection on the tv and try again or try a manual search to pick up one channel and then do a full scan also are you doing a scan to add channels to the current list as I would personally try and do a complete scan for all new channels list and see what happens
Sep 21, 2013 | Televison & Video
I have a multi colored line running across my screen and I can't get my digital antenna channels? Any ideas? Tv is only about a year old and I have unplugged it for an hour to reset it but it didn't w
Hi it sounds like you have multiple problems with your tv. First you said that there were no digital channels. The tv has a bad signal board. The second problem is the colored line running across the screen. That could be two things either the screen itself is bad or your t-con board is bad. The t-con board would be the cheapest of the two to try. You can get parts from www.interliquidparts.com
Dec 13, 2011 | Sylvania LC260SS8 26 in. LCD Television
My remote control's input select button wont work.....how do i do it manually?
Not sure about this particular TV, but usually, you select inputs by channel selector. Go to Channel 1 on TV not Cable or dish, Use the channel selector button on the set itself, go down from 1. You should see somthing like Aux or Line, then aux 2 or Line 2 etc.. eventually (3 clicks or so) rolling around to ch 115. But usually between the highest ch on the set and ch 1 are the auxillary input selections.
Nov 11, 2010 | Emerson EWF2004 20" TV
Vertical line at edge of AV1 channel
hi! he might have adjusted the vertical hold and height including the linearity. normally on the board you would see a trimmer resistor with a label v-hold this is to stop the rolling, v- height for the size of the picture. and linearity for the evenness of the picture from top to bottom.
Aug 28, 2009 | Televison & Video
My vizio 37" plasma tv has a green line running down the right side of the screen
Vizio does not make 37" plasma TV. for the green line problem, does it happen on all inputs or just when you what TV (cable or satellite)? That line should only be present on some channels due to signal processing compatibility. To get rid of it, you can use the horizontal size adjustment and expand the picture side way.
Jul 03, 2009 | Vizio L37 Television
Recording from TV issues: Channel selection...Line 1, 2 or 3???
get it fixed in a shop.
when things break do that.
this dc4000 is an old device.
get the service manual on it ? yet?
or why not upgrade ,
what way to you watch TV, (sources)
antenna
Cable
SAT
what?
Nov 06, 2017 | HP dc4000
53 Hitachi Ultravison TV : Getting Horizontal lines rolling up
ok
this is called viedo noise
you will need to replace capisitor Cc10 its Value is 1000uf @ 16v the cap is a filter On Sw +9v Line , on pin 20 of Ic01, ( or corma Jungle IC)
Dec 30, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Vertival Color Lines
We had the same thing happen to us on the right-hand side. A technician told us yesterday that the Motorola Cable Box (supplied by Shaw Cable) places a border on Non-True HD Channels. Because we didn't place our picture setting to 'full-screen' each time we viewed these channels and burn line was created. He gestimated a replacement screen runs about $800.00 Canadian, but we have a 3 year extended warranty and will receive a new TV. He also said it happens on all big screen tv's that use a cable box creating borders on Non-True HD Channels.
May 04, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Vizio GV42L 42 in. LCD Television Logo
124 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
