Question about Polaroid TDX-02610B LCD TV
My tv went black - Polaroid TDX-02610B LCD TV
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Aug 02, 2010
After few minutes LCD picture went black but sound works ok
most likely the power inverter, also suspect the p/s. best to have a trained tech check it. Julio at milleniumtvsvc@gmail.com
Jul 21, 2009 | Memorex MLT3221 32 in. LCD TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Screen went BLACK!
My Sony FD Trinitron TV did samething, started flashing, then eventually went completely black with volume. I got on internet searched found a solution, i tried it, it worked. unplug tv, remove all screws, remove back. towards bottom right theres a transmitter with a couple of knobs, we plugged tv in and moved knobs around and it worked. Also was extremally dusty, we used computer duster for a better connection. hope it helps you
Jan 26, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
Polaroid TDX-02610B LCD TV Logo
175 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
