Question about Gateway FPD2275W LCD Monitor
My monitor wont show picture and if it does it has a sing saying vga blinking what do i do please help
  • 4 Answers
Check all your cables and in a worst case senario use another monitor or select vga mode, by pressing f8 before booting into windows.
Posted on Aug 08, 2010
Monitor wont turn on help
Hello there, first thing you should do is to check the power cable.You can do that by changing it with PC power supply cable .It is the same. If it turns to be OK then disconnect the VGA cable from monitor and then try to power monitor on.There should be an activity on front power LED. If the power LED is not showing any light at all, then do not go further the unit is not working .Else the power led should blink a couple of times then a window pop up scrolling on the lcd saying :" no video signal" so the unit is OK ..Hope this helps. Cheers.
Dec 05, 2013 | LG FLATRON L1919S-SF 19 inch LCD Monitor
When I power on my I-Inc Ic194D, the blue does come on, after 1 or 2 secs, the screen will blink with white light and it will blink every other 1 or 2 secs. Nothing shows up. Can someone help?
Make sure the DVI or VGA cable is securely plugged into both the computer and monitor. If this doesn't work, try plugging the monitor into another computer. If it works when attached to a different computer, then the issue lies with the computer and not the monitor.
Good luck. Please rate if this was helpful.
Mar 02, 2011 | Computers & Internet
The monitor wont work
plug back to vga and setup multy screan c
Jun 25, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
Hi there, My HP compaq laptop wont startup, Not even POST
You may have backlight inverter baord failure or the lamp has gone out. Can you get the picture if you use the VGA port? Model of the laptop will help. See www.insidemylaptop.com to see how involve it will be to repair/replace the laptop inverter.
Mar 30, 2010 | HP Compaq FS7600 17" CRT Monitor
Monitor Blank, Power light is not on
Your monitor have a bad condensatorin the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive, more than a new monitor) or if you have electronic tools, found and replace that condensator.(cheaper way...)
Anyway, have you tried to replace your VGA card ? The problem could be there too !!
Best Regards!
Jun 24, 2009 | Dell E198FP LCD Monitor
LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
try your monitor to other computer or try other monitor to your computer to see where is the problem
Dec 09, 2008 | Computers & Internet
BenQ FP757 monitor problem
the vga modul can't tobe start power "on",power regulator/switching normal condition. some of the semiconductors on board of the VGA modul ( transistor ) is Shock/dead. I need schema/diagram of this,please........
Oct 30, 2008 | BenQ FP757 Monitor
Dvi to vga
You will not benefit from the DVI input unless you have DVI output on your computer. The great advantage of DVI is that the picture is transferred in digital form all the way from your computer to the individual pixels on the monitor. If you only have VGA output on your computer then you will never get a better picture than by using a good quality VGA cable to link that to the VGA input on your monitor.
The DVI plug is designed to carry both digital and analogue (VGA) signals on the various pins, so "adaptors" exist to allow a VGA monitor to attach to a DVI output on a computer. Monitors may also support VGA input from their corresponding DVI input sockets, but the picture quality will never be better than by using a good VGA cable because it is still not using the digital capability of the DVI interface. What's more, because you may need more adaptors and thinner conductors in the cable, you will probably achieve a marginally poorer picture than with VGA to VGA.
When you next buy a PC or a new video card, get one with DVI to take advantage of your new monitor. In the meantime, your best bet is a quality VGA to VGA link.
Sorry that's not what you were wanting to hear, but I hope it will help you avoid further frustration.
Sep 20, 2008 | Envision EN-985e Monitor
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
