Question about Skeetervac SV-3100 Mosquito Exterminator
Took apart the SkeeterVac as it would not lite after the propane was replaced. When we disassembled the gasket fell apart - what can I make a new gasket out of?
I had the same problem. I've located a gasket company but they may not sell to consumers. Don't throw it away yet! I hope to have an answer by 12 Aug.
Posted on Aug 11, 2010
  • tapeitup Aug 12, 2010
    Skeeter Vac Update.
    I found gasket material athttp://www.macroseal.com. I spoke with a few nice folks over there and explained what I needed it for and they suggest their product KLINGERsil C-4401. There is a minimum order of $25 which will get you a 15" x 30" x 1/16" piece of material. I hope this helps.
My skeeter vac will not stay lit but gets lots of gas
If it lights, use a c-clamp or something to keep the fuel button pressed in until it will stay lit without the button pressed. This took me 3 hours before it would finally keep running normally. If that doesn't work, the jet and engine chamber might need cleaning. This takes some additional work and you may need to make a new fiberglass gasket since the original one falls apart after a few seasons.
May 13, 2012 | Skeetervac SV-3100 Mosquito Exterminator
I was changing the front disc brake pads on my 2008 Suzuki Boulevard S50. I took the two bolts out that hold the calipers together which caused the fluid to leak out and a small rubber gasket fell out ....
You will need to buy a new rubber gasket kit for caliper from suzuki shop
It is not usual to pull caliper apart for pad replacement, normally unbolt caliper off fork leg and lift of the disk
Jul 08, 2011 | 2008 Suzuki Boulevard
Machine will not light. It is three years old and I did not use it last year. Replaced battery and a full propoane tank.
I had same problem in 2nd season of use. Took apart unit (not easy) and found a tiny spider web blocking the propane jet. Be careful, the gaskets fall apart when disassembled.
Jun 15, 2010 | Skeetervac SV-3100 Mosquito Exterminator
Can we convert Laars lite llg175N to propane from natural gas? If so how
You can convert this laars with a new burner tray, new gas valve etc..I have lots of customers who was the visa versa to you Natural to LPG and LPG to Natural..I offer an exchange service please see..
http://www.laarsman.co.uk
Miles
May 20, 2010 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
LG LDF7920ST dishwasher, screw fell into wash pump
Have you tried using one of those tools that have a magnet on the end to see if you can get the screw out? Good luck!
Mar 04, 2010 | Dishwashers
DESA Propane Heater Valve Apart
Do,not override the safety features on any units unless youre qualified. These are not overides ,but safety switches to tell when something is not right! Anyway, its time for a fall service overhaul or kit ---plug---fuel filter---2 air filters --clean the flame sensor---and vanes in the pump replaced.You can buy the kit and parts that you need a your local lawnmower repair shop or have them to order them!
Dec 14, 2009 | Desa International Propane Portable...
Pilot lite will not stay lit, have a full tank of propane
YOU WILL HAVE TO TAKE THE TUBE FROM THE CONTROLLER TO THE PILOT TIP APART AND CLEAN OUT THE ORFICE AS THE SPIDERS MAKE NESTS IN THEM.
Nov 12, 2009 | Hayward H Series Pool & Spa Heater 400k...
Took apart carb cleaned and now there is no mid or high range
did u install new gaskets, the engine might be sucking air from outside the carbs. u can use a propane torch (not light) spray a little around outside of the carbs, see if engine sounds different, if it does... leaky gasket.. u might check there is no unplugged vaccum hose.
Jul 27, 2009 | 2000 Harley Davidson XL 1200 S Sportster...
Skeetervac SV-3100 Mosquito Exterminator Logo
1,176 people viewed this question
Top Skeetervac Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Skeetervac Pool and Spa Expert? Answer questions, earn points and help others
