Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cant get the mower to turn over. Have good battery voltage and the relay clicks. there is 12+ volts to the starter when I engage the key. How do I check the starter/solenoid further? or is it clearly a bad starter? Thanks
I've pulled the cover off to where I can see the starter and tried to start it and the starter engages and it tries to turn over. I pulled the plug and grounded it to the block and tried and got no spark. I'm begining to think coil. What are your thoughts?
Thanks
Tim
Posted on Jun 18, 2011
Get a wire that goes to the positive terminal on the battery and touch it to the bolt on the starter and see if it works then. if not, the starter could be bad, screw the plastic gear back up til it engages in the flywheel on the engine and hand turn the lawnmower with the starter gear engages to loosen it up then try
Posted on Aug 02, 2010
Starter on JD 2130 tractor quit.Put on new solenoid but still doesn't engage.12 volts at starter but only about 7 volts on ignition wire when you turn the key.What's wrong?
dead battery cell , bad ground on the battery
the battery can read 12 volts at rest but when the starter is engaged , in a bad battery , that voltage will drop to what you have and so the starter will not engage or turn the engine
Mar 24, 2018 | Heavy Machinery
I have a 2008 la 115 john deere riding mower. It won't start in less I put a large screwdriver on the solenoid. the fuse looks good as well. I replaced the ignition switch and solenoid too.
When you try to turn over engine with key it turns over slowly and stops? It acts like starters not working properly? If this sounds like it and it's a single cylinder Briggs and Stratton engine ohv's your valve specs are off they need to be checked and adjusted every 200 hrs. If you need further assistance let me know. Wadembly@aol.com or call 831-578-4034 pacific standard time ( California)
May 18, 2015 | John Deere Garden
You can hear the solenoid engage but the starter doesn't turn. After 5-12 tries it starts.
If you got it recently go and get it exchanged, but most starters only have a 90 day warranty
Feb 11, 2015 | 2004 Dodge Caravan
My yardman dx 70 secondhand wont start nothing when I turn the k3y
could be the starter relay or a bad power wire. or the wire that goes from ignition switch to starter relay has just fallen off. to start I would put a volt meter test the voltage at both ends of the relay while you turn the key. you have a positive in from battery wish should always read 12 volts, the other big wire goes to the starter that should only show 12 volts while key is in the start position. there should be at least one small wire on the relay that is a the power soulse coming from ignition when the small wire sens a signal it throse a swith inside the relay that opens the curent from battery to go all the way to the starter
May 05, 2014 | Garden
1995 Isuzu Rodeo won't start all of a sudden.
Check connection battery,could be starter.
Jun 05, 2013 | Cars & Trucks
Would a bad solenoid cause a clicking sound when you turn the key but starter want engage
Yes and no. If you have a test light or voltmeter you could check the heavey wire which comes from the solenoid and goes to the starter. While attempting to start the machine if you have 12 volts or better(or the test light is nice and bright) on the starter end of the wire than the starter is at fault. If however there is no voltage at the starter and the solenoid is clicking your fault is likely the solenoid. This is all assuming your battery is at 12 volts or better and fully charged.
Feb 23, 2013 | Craftsman Garden
Cub Cadet Wont Start.
Is the blade engage off? On my riding mower, I shut if off and the blade was still engaged. Drove me nuts for 3 days and all of a sudden, I got lucky.
Oct 03, 2012 | Garden
My 2006 buick lacrosse wont start radio and lights work but its not saying nothing when i try to crank it
Hello! Do you hear a click when the key is turned?...If no click is heard either the ignition key, the Crank relay, the starter, or the battery are suspect...Having lights and radio does not mean the battery is capable of running a starter motor......Put a meter on the battery...should read 12.5 volts...Turn key...Does voltage drop to 8 or 9 volts? Bad battery...If all is well with battery and connections to it...Check the starter fuse # 33 in the under hood fuse/relay box...If the fuse is good that click you should hear is from the Crank Relay in that box...If all of the above is OK connect your meter to the Purple wire that is connected to the starter motor...When the key is turned 12 volts must be on that wire...If there is the starter motor is defective...So, #1...Do you hear a click when key is turned...That would point at a bad starter or weak battery...#2...If you do not hear a click bad fuse #33, bad Crank Relay, bad ignition switch...#3...If fuse is good Bad Crank Relay or Ignition switch; Crank Relay is a low cost item ($10)...Replace Relay...Stop there and send a comment as to results...Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
May 06, 2012 | 2006 Buick LaCrosse
I installed a new solenoid, new battery, new spark plug. checked all my connections. and all i get is a clicking noise when i try to start the motor. could the starter be bad ? would it make that clicking...
Good morning Brian.
You need to have a current tester to make sure. If you don't have one, you can buy a cheap one for less than $10 that will get the job done.
1. Test the battery. Make sure you have at least 12 volts DC across the terminals. If not, charge the battery and retest. Even new batteries can be discharged or defective.
2. Test the voltage at the solenoid. You need at least 12 volts to each of the terminals when the key is engaged to the start position. You may need a helper to turn the key while you test the current. Failure to get current to the lower terminal on the solenoid is usually caused by a defective ignition switch or a defective/dirty safety switch. Most mowers have at least 3 safety switches. Your clicking noise is probably the solenoid engaging and is a normal noise.
3. Test the voltage at the starter. You need at least 11.2 volts at the terminal on the starter motor. If you have enough current, and the starter is still not spinning, then you have a bad starter. Sometimes a failing starter can be used a few more times by lightly tapping on the side of the starter motor with the wooden handle of a hammer. If the brushes in the starter are sticking, then tapping on the side will occasionally allow the starter to work. This is a very short-term repair. The starter will either need to be rebuilt or replaced.
Good luck.
Oct 25, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My 2002 suburban will not start
First thing I would try is checking the actual battery voltage. Most batteries should be roughly 12.5 if new when sitting at idle. If the lights dim and relays click this is normally a sign of a weak/bad battery connection or possibly a discharged battery. If the battery has good voltage, and the lights continue to dim I would suspect checking the primary wire going to the starter with a 12 volt test light. You will want to check the smaller wire going to the starter and have someone turn the ignition to start. You should have 12 volts there. If you have 12 volts and the starter does nothing I would suspect a faulty starter at this point.
Nov 14, 2008 | 2004 Chevrolet Suburban
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
325 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
