Question about Motorola Mobility RAZR V3
Power button doesn't work
My phone is only about 2 months old, and the power button doesn't work. It stopped working once, and I typed in the #000...(or something) code, and it worked again for a little while....then again it stopped working. The main issue now is that the battery was removed, and I can't turn it on. Is there an alternate way to power the phone on? All the other buttons have never had a problem, so the keypad should be fine. Any ideas...Please help!
Thanks!
  • evilemprzurg Nov 20, 2008
    I actually found an easy fix!
    Just take a USB cable and plug it into your phone and your computer. The computer detects the phone and makes it turn on! The power button still doesn't work, but as long as I don't pull out the battery, all's good!
What did you do to type in #0000?
how do i do that?
the phone is off
and my power button is broken so i can't turn it on either
Posted on Nov 20, 2008
    Sergeant:
    Champion:
  • 283 Answers
Gotta change your flex, it's faulty bring to the pro's now,, you cant fix it by replacing it, and you can damage u'r fone in simple mistake... gud luck
Posted on Apr 25, 2008
Nokia x3-02 - power button stopped working
your question states SOME years . none were made to last forever and possibly your power button could be cleaned check with any local TV repair shop to see if they can clean the contacts for you .
Aug 18, 2016 | Nokia X3-02 Unlocked Touch And Type Gsm...
No remote for television. television will not come on. is there a procedure to get the television to come back on without the remote
disconnect from power for 2-3 minutes and try the same old operation again.
if it still doesn't work then you need professional help.
Sep 25, 2012 | RCA Televison & Video
Kohler Generator has a noEc error code
My 11 month old Kohler 14RESL stopped working sometime this month. The GFI outlet to the trickle battery charger tripped and the battery charger went dead and so did the battery. When I realized the GFI had tripped, I reset it and the trickle battery charger started recharging the battery overnight. In the morning I tried to start the generator by pushing the run button - nothing happened except a message 'noEc' appeared on the status screen. I called Kohler and was referred to their local distributors. After a whole day of phone calls to many distributors, I finally found one, Kraft Power, who would come out on an overtime basis and fix the problem. I chose Kraft Power because they were the only company who knew what 'noEc' meant. They told me that since the generator had lost all power (no trickle battery charger), the engine had lost it's configuration! I have worked in the technical field for 25 years (computers, networks and remote diagnosis) so this answer was particularly troubling. THIS SHOULD NOT HAPPEN. The technician had to connect to the port on the controller, bring up Site Tech on his laptop, and enter two pieces of of information into the configuration. 1) 14RESL and 2) the engine type. We had to use a mirror to read the engine type as it was under the oil filter!
Sep 17, 2012 | Kohler 12 kW Emergency Power System -...
My Dell D600 laptop stopped working today. Coincidentally, I had just turned it off to try running a test on the RAM because the PC had been slow and locking up for the past month or so. Anyway, when I...
try this:
1- deattach the RAM , run the laptop without (RAM) you must hear som beeps
2- put the ram back again in the same slot
if it doesn't work try other slot
Feb 07, 2012 | Dell Computers & Internet
The power button on the bh-m20 does not work is there an easy fix
I buy these 3 at a time and they last about 2-6 months, then the power button stops working.
I am unable to figure out what goes wrong, and I am sure they manufacture this fail.
"planned obsolescence".
Oct 25, 2010 | Cell Phones
Can i know my Nokia Puk code?i can't find any Puk code inside my nokia box
Nokia 6110 Secrets:
*#06# for checking the IMEI (International Mobile Equipment Identity) Information you get from the IMEI:
XXXXXX XX XXXXXX X
TAC FAC SNR SP
TAC = Type approval code
FAC = Final assembly code
SNR = Serial number
SP = Spare
*#0000# To view Software Version.
*#6110# Try this code if the above code doesn’t work.
#746025625# [*#SIM0clock#]
Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn’t work with software version 4.59.
*#92702689# [*#war0anty#] You don’t need the warranty-codes any more – you can just scroll through the information like in any other menu. It has the same data as 81xx and 31xx phones (with “Edit” button for purchase date, and “User data transfer”). Menu:
1: Displays Serial Number.
2: Displays the Month and Year of Manufacture (0997)
3: Displays (if there) the date where the phone was purchased (MMYY) you can here set the Purchasing Date (Warning: You can only do this once – so be careful what you write…)
4: Displays the date of the last repaired – if found (0000)
6: Does anyone know if this is for upgrading the phone’s EEPROM?? (Transfer user data?)
Enhanced Full Rate Codec (EFR):
On: Enter *3370# and EFR will be activated after a reboot of the phone ( consumes more power )
Off: Enter #3370# and EFR will be switched off after a reboot of the phone.
Half Rate Codec:
On: Enter *4720# and Half Rate coded will be activated after a reboot of the phone ( better standby time )
Off: Enter #4720# and Half Rate coded will be de-activated after a reboot of the phone
Jun 23, 2010 | Cell Phones
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Disney TV (only 5 months old) just stopped working.
I have a Disney cars tv with built in dvd player and after 2 months it stopped working. The power will not turn on, the light just flashes once and then goes off. I have tried replacing the fuses and it did not work, could you please help me.
Jul 05, 2008 | Disney 13" TV
Error code 6502
1-- With the printer unplugged, remove the ink cart to the right ,
2--Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3--The beeper may sound once ,Then Unplug the printer ,then power back up and reset the printer electronics ,open the printer and this process is finished. I believe this should take care of your issue, it's basically a cold reset for the printer, Give it a shot...
May 11, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Motorola Mobility RAZR V3 Logo
146 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
