Question about Emerson Televison & Video
Three is a thin line going right down the middle of it. What is it? can i fix it?
  • 11,361 Answers
If they are solid color vertical lines from the top to the bottom of the screen, that is the sign of bad LCD panel, very expensive to replace.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Aug 02, 2010
I have vertical line going down the middle of my tv. is there a way to fix it?
Your panel is defective. Only fix is to replace - not cost effective. You need a new TV.
May 17, 2012 | Sylvania LC220SS1 22 in. LCD TV
Hi.i have a problem with my tv.the picture is not visible but the picture has come closer means it has a white is in the middle in that line only the picture is coming but how to see it is a thin vertical...
a defective horizontal stage could caused this type of defect,or the deflection yoke is defective and should be fixed right away..have a qualified tech check the tv right away.dont use the tv
Jul 17, 2011 | Televison & Video
I have an older model Hitachi 32" ultravision CRT tv. the video just collapsed into a thin horizontal line (about 1/4"). Video is fine. Any help would be greatly appreciated. Thanks.
TURN IT OFF AND DO NOT TRY TO USE---if a thin line left to right in middle of screen it is vertical problem---the set should shut down but even seconds count here--this can burn a mark on all three picture tubes instantly and it is permanent.
Problem if small line left to right in vertical circuit.
Let me know what you know and I will try to help--I know these sets very well.
SD TECH
Sep 22, 2010 | Hitachi 61SWX10B 61" Rear Projection...
The pixels (I assume it is) are going out one by one. It's been an ongoing problem that started with one very thin line right down the middle of the screen. It has now progressed like a cancer over the...
No need, the screen is indeed dying and there is nothing that even the can do to save it.
You must replace it, and quickly, otherwise when it will finally fail completely it may fry the video chip.
Aug 10, 2010 | Toshiba Satellite P105-S6024 Notebook
Horizontal Line running down my Laptop Computer Screen
You can try changing resolution to something else and then back.
You can see if your colors are 32-bit.
The fact that you "fixed" it is probably an coincidence. Once you start getting anomalies like that, it usually means a new screen.
Oct 03, 2009 | Dell Computers & Internet
Problem with the video. There is display of thin horizontal line in the middle, when i turn on the TV.But sound is good.
Well I have some questions:
Is this a plasma ? If so is the line going up and down or from left to right ? If going up and down it is an address problem and most likely the panel will need to be replaced or a part on the address boards has gone bad. If its left to right then the scan board has a bad component in it and will need replacing.
Hope this helps and ask more if you want
May 07, 2009 | Philips Televison & Video
THIN BLACK LINE DOWN CENTER OF TV
how do you solve this problem of the black line down the middle of the tv?
Jan 26, 2009 | Hitachi 42HDS69 42 in. Plasma Television
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Aug 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
We bought a Philips TV (model : 42PF9966/79) three years ago. Intermittently we are getting a thin black horizontal line through the middle of the screen. What is causing this?
The model number you listed is bad. I think the last 2 numbers should be 37. But it sounds like a plasma tv. In that case the problem can be a bad connection from the driver board to the panel.
Take off the back of the set and reseat ALL of the ribbon cables on the far left and far right sides of the set. If this does not fix the problem, the panel is bad. This is not worth fixing. Buy a new tv.
May 26, 2008 | Philips Televison & Video
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
51 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
