Question about Zebra P210i Thermal Card Printer
The printer Zebra P210i always say Printhead is open, and cannot print.. How to make it works regularly back?
5 Suggested Answers
Selvol
  • 115 Answers
SOURCE: Eltron P210i printhead replacement and aligment
Can you go into printer properties for the Eltron?
Select Prefrences then Device settings - tools.
You can set the offsets for the axis's.
You can also send direct commands.
+OFP Command - Adjust X-Axis Patch Offset
Description Establishes X-Axis patch positioning setup
NOTE: See !OFP Command for check of current offset.
Syntax
<Esc># 1 +OFP p1 p2
Parameters p1 = Patch Selection
Where:
0 = upper
1 = lower
p2 = Offset
Where:
Range = 100~800
Posted on Nov 24, 2008
ADRideau
  • 54 Answers
SOURCE: how do I get a Zebra p210i to work with vista
The link here indicates that this driver is good for all Operating Systems.
(http://drivers.softpedia.com/progDownload/Zebra-P210i-Printer-Driver-200-Download-28375.html)
Hope it helps!
-AD
Posted on Nov 26, 2009
SOURCE: Sizing and Orientation problem on Zebra 140 Xill
Check the size of report-page and if it is in inches or cm.
Posted on May 28, 2010
ozztech
  • 285 Answers
SOURCE: Zebra P210i Win7 Driver
Please take note P210 is not supported on Windows 7 yet at the moment.
Best regards
Posted on Nov 25, 2010
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
Best regards
Mar 09, 2010 | Zebra P210i Thermal Card Printer
LP2844 Printing light
Click start on your computer, go to control panel-printers and faxes folder. Highlight your Zebra printer and select 'printing preferences'. You are looking for a place to turn up the heat settings "Head Settings" or "Heat Settings". These get reset down to the lowest setting when you continually open the cover without turning the printer off first....exposing the printhead to light.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
Want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
May 04, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Problem with zebra p420i
Go in to control panel,
Printers. RT Click On p210i,
Properties, Device Settings Tools.
Send this Command using the Direct Commant
input Box. Just the First line..
1 +LC 0
Not This--
0
= Counter Value
Dec 16, 2008 | Zebra P210i Thermal Printer
Usually with Eltron and Zebra printers all you have to do is turn the power off, change the print head, turn the power back on and re run your software to get the forms to reload. If you miss any of these steps you will run into trouble.
As long as the labels didn't get moved, it should work once you restart your computer and re run the software you print your labels with.
Aug 12, 2008 | Zebra P210i Thermal Printer
Printing problem
Try to clean the light sensor inside the printer, you will see a white led on the top part of the case, match it to the bottom you will see a small hole on a plastic peice, that is the hole for the sensor.
Oct 29, 2007 | Zebra P210i Thermal Printer
Printing problems
Sounds like the heat is set too high.
Aug 18, 2007 | Zebra P210i Thermal Printer
Zebra P210i Thermal Card Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
