Question about Norelco Health & Beauty
Norelco mod 850rx....what is the value of the dropping resistor between the ac input and the dc rectifier.
SOURCE: Fried resistor, need value for R801
Brown/ Black/ Brown/ Gold It is a 100 ohm +/- 5%
Posted on Feb 11, 2008
  • 12 Answers
SOURCE: power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Posted on Sep 22, 2008
SOURCE: DC FEEDBACK FAULT ON CHLORIDE EDP70 30KVA UPS
Sir,
I have edp70 30kva 3:3 out problom is that ups is just given me the 20 to 30 sec backup. and output 2 phase 220v last phase is given just 15v ac. plz send me the tecnicaly solution.And plz reply as soon as my email, henchman11@hotmail.com
Posted on Jun 15, 2010
SOURCE: Motherboard resistors RV2 and RV3
RV1, RV2, and RV3 are capacitors. They're actually dark green in color because they're made primarily for automotive applications. If you remove one and measure it with a capacitance meter you can find the value. On a 600M/D600 I believe they're 150pF, but on other boards they may be 100pF. Digikey part numbers for them are 490-4962-1-ND for the 100pF, or 490-4767-1-ND for the 150pF. Good luck!
Posted on Aug 02, 2010
SOURCE: i have a Minwa MW79 7 output A.C-D.C adaptor it
I have the same adapter and the same problem, the 2 smaller once are ok, the bigest one inbetween capacitors diodes and transformator is burned out it is so hard burned that it cannot be read if you may be have this one OK can you read the values? i could read the two smaller ones
Posted on Oct 18, 2010
Why does the relay in my RCA TV click on then off when the power button is pressed? Isn't the 220v at the horizontal output too high when just plugged in ?
I don't have your previous question but rest assured that diodes do not reduce voltage
their soul purpose in electronics is to act as a one way valve for current flow
they flow from positive to negative but stop reverse current negative back to positive ( hence their application on a rectifier bank to change ac current into dc current)
Resistors drop voltage by dropping current flow
Oct 24, 2015 | RCA Televison & Video
Fluke 179 multimeter showing wrong reading in AC, DC voltage, rest every thing working ok
input protection circuit is blown , see if you can find fusible resistor and check for open circuit (should be 1kOhm) - big resistor on the right straight from the Volts input
Mar 15, 2013 | Fluke Networks Fluke 179 Electricians...
Is HQ9 compatiable with HQ55?
No, philips norelco HQ56 replacement heads compatiable with HQ55
philips norelco HQ56 for norelco 100db, 110db, 1323, 2005c, 200sc, 300sx, 3405lc, 3601x, 3604x, 3605x, 3801xl, 3805xl, 3865xl, 400dx, 410db, 4401lc, 4402lc, 4403lc, 4404lc, 4406lc, 4413lc, 4414lc, 4417lc, 4601x, 4602x, 4603x, 4604x, 4605x, 4606x, 4607x, 4608x, 4625,x 4805xl, 4807xl, 4816xl, 4816xld, 4817xl, 4817xld, 4821xl, 4825xl, 4825xld, 482xl, 4845xl, 484xl, 4852xl, 4853xl, 4861xl, 4865xl, 486xl, 4885xl, 500rl, 501rl, 505rl, 5426lc, 5625x, 5812xl, 600rx, 605rx, 6423lc, 6424lc, 6613x, 6614x, 6615x, 6616x, 6617x, 6618x, 665rx, 6843xl, 6844xl, 6853xl, 6854xl, 6856l, 6856xl, 6863xl, 6940lc, 6945xl, 700rl, 705rl, 710rl, 715rl, 720rl, 725rl, 750rl, 800rx, 805rx, 815rx, 825rx, 835rx, 850rx, 875rx, 885rx, 885rxac, 895rx, 900rx, 905rx, 915rx, 935rx, 945rx, 950rx, 955rx, 965rx, 968rx, 975rx, 985rx, hp1318, hp1319, hp1327, hp1327d, hp1328, hp1328e, hp1328s, hp1337, hp1337c, hp1601, hp1602, hp1604, hp1605, hp1606 and hp1608.
Feb 02, 2013 | Norelco 3405 LC Electric Shaver
Are Norelco HQ9 Blades interchangeable with HQ55 blades?
philips norelco HQ56 replacement heads compatiable noelco HQ55 blades.
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
Model 27LCDB03B-simply appears to be "dead" won't power up-not the fuse
Hello Chris, Hi, your TV's power supply section is not functioning properly. If the fuse is in good shape, then the auxiliary power section of the power supply is not functioning, this section powers the switching oscillator and IC that sends the pulse to the switching element like power transistors to create a main secondary voltage. the main secondary voltage is the circuit that produces all voltage needed source by the TV. what you can do if you are up to it.
A. Visualize any bulging capacitors, replace them. B. Measure the voltage across the following section in particular order so we can find the faulty parts.
  1. the AC input on the Power supply board. (none means open switch or power cable)
  2. the AC after the line filter circuit. (none means open line filter)
  3. the DC on the filter capacitor. (none means problem on the rectifier)
  4. then the AC on the switching element or input on the main transformer. (most likely you won't have any voltage reading hear.)if you do have continue.... (none means you scratch your head, this is the hardest part) check all low value resistors, high wattage resistors open or shorted diodes.
  5. the dc on the secondary filter capacitors.
If not have this checked by a technician, its to complicated for you.
Mar 12, 2011 | Thomson Televison & Video
3-phase recty fier not output voltage 230V 10V
What is the type (input, output, power) of the rectifier.
If controllable - may be the control PCB or thyristor.
If not controllable - 10 V DC instead of 230 V DC is hardly believable.
In this case the rectifier may be OK, but the input - low.
If you have a voltmeter, check the input AC and the output DC if the output has about 200 V AC you may have shortened diode.
Jul 02, 2010 | Electric Measuring Tools & Sensors
I have the Behringer 10watt amp used but it wont power on at all...
Please open the amplifier and check from the power supply to the output section. You will need a multimeter to check for the ac input , then the fuses, the switch continutiy and the output secondary section ac. Now the DC to the circuits, the rectifiers, the filter capacitors, fusible resistors. Once the power is coming over to the main board and to the output drive, the premap section needs a check . The fault will be around this section if the outputs are clean. hope this helps.Good day
Jun 10, 2010 | Behringer Audio Players & Recorders
I have a extech 380920 ac/dc clamp meter that is out of tolerance looking for a manual or schematic for it.
here is the web page for this unit. http://www.banulista.us/tools/Electrical-163105.html
it is adjustable and has adjusting screws to reset readings but you have to have a power supply that is accurate to test it with, to reset ohm values you may use a resistor from radio shack to measure resistance. get a 5 ohm resistor and a 10,000 ohm resister with a gold 5% band to test the unit. If you need help setting up the testing for amps and ac and DC voltages reply to this post and I will give you instructions on how to set the meter to read within .2 tolerance.
Mar 17, 2010 | Extech AC/DC Clamp Meter 400 Amp, Dual...
Front Pannel Display
Check heater voltage ,thats should be arround 4 volts ac ,in some cases it can be dc also.Sometimes what happens that the resistor inthe series off heater supply gets high value and voltage drops.
Dec 04, 2007 | Panasonic DMR-ES10 DVD Recorder
Health & Beauty Logo
65 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
