Need more ram for an ASUS P5S800-VM motherboard. Not sure what to get. Need 2gb. Assume 2x1gb. DDR or DDR2?. Single sided or double sided? I know I need unbuffered non-ECC. Thanks for any help you may be able to forward. Yours sincerely Colin Sinclair
    Sergeant:
  • 221 Answers
Here is a list of all compatible memory for your motherboard. If you click on 'get price', you will be directed to a page that tells you where you can buy the memory and for what price. Hope this helps!
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?id=8&SysID=21213&mfr=ASUS%2FASmobile&model=P5S800&root=&LinkBack=&Sys=21213-ASUS%2FASmobile-P5S800-VM+Motherboard&distributor=0&submit1=Search
Posted on Apr 25, 2008
Can we use DDR2 PC-5300 RAM on P4R800-VM ?
No, you can only use DDR ram.
4 x DIMM, Max. 4 GB, DDR SDRAM ,Non-ECC Memory
Dual Channel memory architecture
Note: Supports one single-sided PC3200 (DDR400) DIMM per channel only
You can see the other specifications here:
http://www.asus.com/Motherboards/Intel_Socket_478/P4R800VM/#specifications
Here you also find drivers and a manual.
Aug 24, 2011 | ASUS P4R800-VM Motherboard
Dear Expert, I have Asus motherboard P5S800-VM. Now,There is 1.5 Gb ram(512MB+1 GB).If I plug 2Gb ram (1+1), then PC is working very slowly.What can I do for this problem . ram:2x1Gb Kinsgton thanks
First verify that you are using the proper speed of RAM. Second, check the BIOS and make sure that recognizes the RAM you have installed. Sometimes you have to manually set the RAM size in the BIOS in order to get it to work. Finally, I have had several issues with Kingston RAM on different motherboards even when it is the proper type so you would want to try a different manufacturer.
Jul 08, 2011 | ASUS P5S800-VM Motherboard
Want to upgrade my memory. What do I buy? What kind of memory stick is installed? DDr? , DDr2?,.
Here is the Crucial site that gives the specifics on your motherboard:
http://www.crucial.com/store/listparts.aspx?model=P5S800-VM
DDR PC2700 or DDR PC3200. Max of 2GB (1GB per slot)
Thanks for using Fixya.
Jan 01, 2011 | ASUS P5S800-VM Motherboard
Asus p55800-vm takes what kind on ram the probleme is i want to order ram i need? thanks for the help
Asus P55800-VM motherboards support up to 2GB of DDR DIMMs of either 266, 333, or 400 MHz.
Nov 15, 2010 | ASUS P5S800-VM Motherboard
Is Asus P5PE-VM series motherboard supports 2GB RAM
i have a problem with ASUS P5PE-VM motherboard, with 2 GB DDR 400 (2x1GB, Kingmax) the system (Win XP Pro or Vista) doesn't start. it hangs up in different stages.. what's wrong?
Oct 05, 2010 | ASUS P5PE-VM Motherboard
Which kind of RAM my motherboard is compatible?
It supports maximum of 2 GB of DDR RAM
DDR here means DDR 1 and not DDR2 or DDR3
Rate it, if it helps.
Aug 04, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
I can't recognize what specific RAM this motherboard accepts..
Dear sir,
In reply to your post- Generally now a days we use DDR400 RAM(DDR 1) for this type of motherboard.So DDR 400 RAM is More compatible then other RAM,you can use this RAM for your motherboard to obtain good performance.
good luck
chandrashekhar
Compatiblity issue..
You may install up to 4GB of DDR RAM in this motherboard. It does not use DDR2.
This is from your manual:
Dual-channel DDR400 memory support
Employing the Double Data Rate (DDR) memory technology, the motherboard supports up to 4GB of system memory using DDR400/333/266 DIMMs.
If you would care for the manual, here is a link:
Asus P5P800-VM Manual
Apr 03, 2009 | ASUS P5P800-VM Motherboard
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
Supporting the DDR2 RAM
Asus site says the motherboard supports DDR or DDR2 RAM up to a max of 2GB.
http://www.asus.com/products.aspx?l1=3&l2=11&l3=0&model=814&modelmenu=1
Oct 21, 2008 | ASUS P5VDC-MX Motherboard
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
